Go Back   Pelican Parts Forums > Porsche Forums > Porsche Cayenne & Macan Forum
Information Junky
island911's Avatar
Lightbulb Interior Lights dead. Anyone BTDT?
Floors illuminate, as do the marker lights on an open door. The main cabin lights stay completely dark - no manual override.
I've checked the fuse (fine) but expecting it may be a control unit.
Anyone have/fix this problem?
Old 10-06-2019, 06:04 PM
Information Junky
island911's Avatar
And just like that... the lights are back working again.
No idea how long that will last.
Old 10-07-2019, 06:07 AM
Information Junky
island911's Avatar
work / don't work . . . :-/
Does anyone know where the control unit lives?
Old 11-11-2019, 08:54 PM
My other ride is a C-130J
RNajarian's Avatar
Not sure if this helps . . . A guy on Rennlist had a similar problem. Though his problem ended up being a bad fuse.
Could it be a relay? A bad battery? Or . . . Back in the day I bought a dimmer module from Performance Products for my 944. When it went bad the courtesy light went dark. Does the Cayenne have a similar module, and of course where is it?
https://www.renntech.org/topic/36648-cayenne-interior-lights-stopped-working/
Is this the part? Or one like it? (I think this one is from a 928) it is a light delay relay
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic
2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer
Previously Owned Art from Stuttgart
2000 Boxster -1983 911 SC Cab -1984 944 N/A
Old 12-08-2019, 07:16 AM
Information Junky
island911's Avatar
Thanks for the reply. The problem persists - sometimes the lights work, sometimes not. :-/
I really haven't had the time to delve into it more. Maybe next year.
Old 12-30-2019, 09:47 PM
Banned but not out, yet..
RSBob's Avatar
You pulled up the front carpets and checked for moisture? A lot of wiring runs under the carpet and can corrode if it is wet due to plugged cowl drains.
Also an old battery can be the blame for a host of issues. Check the voltage
Old 01-28-2020, 10:25 PM
Information Junky
island911's Avatar
Good thought. I've experienced plugged cowl drains before, years ago, but that made a sloshing sound. Also, with all this rain lately I expect that if there was a leak the windows would be often fogged on the inside.
The battery is in good shape, - I just recently parked it for two weeks with the alarm on, it restarted w/o issue.
Maybe there is a common ground that is flaky.
Old 02-07-2020, 10:58 PM
Porsche 944S Club Sport
guru944's Avatar
Send a message via AIM to guru944
Ground Loops in Electrical circuitry.
add 1n4001 rectifier diode(s) on leads to ground.
Works... Did this mod also for rear tail lights.
keep me posted....Later
Guru944
2006 955 Cayenne S Titanium Series - Marine Blue, 1987 Porsche 944S Club Sport.
1987 Buick Turbo-T Lightweight "Great White", +500HP, TA49 Turbo.
http://www.blackbirdmotorsports.com, 944/951/968, 911 and 955/957 Performance Solutions.
Thank you Lord, for your Loving Kindness, Tender Mercy, and Grace. Only You are Faithful.
Old 02-21-2020, 07:36 AM
stormcrow's Avatar
Could be a bad relay as pictured. When they start to fail they sometimes act erratic. My girl friends mustang had that problem with the start relay. Sometimes when she turned the ignition to start the car nothing would happen. Did some research on youtube and replaced the relay. No more problems starts every time.
SteveKJR
Proud Owner of a 78 911 SC Targa
"A Porsche does more then just go fast in a straight line"
Old 02-27-2020, 01:40 PM
