Information Junky
Floors illuminate, as do the marker lights on an open door. The main cabin lights stay completely dark - no manual override.
I've checked the fuse (fine) but expecting it may be a control unit. Anyone have/fix this problem?
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
Information Junky
And just like that... the lights are back working again.
No idea how long that will last.
Information Junky
work / don't work . . . :-/
Does anyone know where the control unit lives?
My other ride is a C-130J
Not sure if this helps . . . A guy on Rennlist had a similar problem. Though his problem ended up being a bad fuse.
Could it be a relay? A bad battery? Or . . . Back in the day I bought a dimmer module from Performance Products for my 944. When it went bad the courtesy light went dark. Does the Cayenne have a similar module, and of course where is it? https://www.renntech.org/topic/36648-cayenne-interior-lights-stopped-working/ Is this the part? Or one like it? (I think this one is from a 928) it is a light delay relay
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic 2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer Previously Owned Art from Stuttgart 2000 Boxster -1983 911 SC Cab -1984 944 N/A Last edited by RNajarian; 12-08-2019 at 06:12 PM.. |
Information Junky
Thanks for the reply. The problem persists - sometimes the lights work, sometimes not. :-/
I really haven't had the time to delve into it more. Maybe next year.
Banned but not out, yet..
You pulled up the front carpets and checked for moisture? A lot of wiring runs under the carpet and can corrode if it is wet due to plugged cowl drains.
Also an old battery can be the blame for a host of issues. Check the voltage
An air cooled refrigerator. ‘Mein Teil’ |
Information Junky
Good thought. I've experienced plugged cowl drains before, years ago, but that made a sloshing sound. Also, with all this rain lately I expect that if there was a leak the windows would be often fogged on the inside.
The battery is in good shape, - I just recently parked it for two weeks with the alarm on, it restarted w/o issue. Maybe there is a common ground that is flaky.
Porsche 944S Club Sport
Ground Loops in Electrical circuitry.
add 1n4001 rectifier diode(s) on leads to ground. Works... Did this mod also for rear tail lights. keep me posted....Later
Guru944 ![]() 2006 955 Cayenne S Titanium Series - Marine Blue, 1987 Porsche 944S Club Sport. 1987 Buick Turbo-T Lightweight "Great White", +500HP, TA49 Turbo. http://www.blackbirdmotorsports.com, 944/951/968, 911 and 955/957 Performance Solutions. Thank you Lord, for your Loving Kindness, Tender Mercy, and Grace. Only You are Faithful. |
Could be a bad relay as pictured. When they start to fail they sometimes act erratic. My girl friends mustang had that problem with the start relay. Sometimes when she turned the ignition to start the car nothing would happen. Did some research on youtube and replaced the relay. No more problems starts every time.
SteveKJR Proud Owner of a 78 911 SC Targa "A Porsche does more then just go fast in a straight line" |
