-   Porsche Cayenne & Macan Forum (http://forums.pelicanparts.com/forumdisplay.php?f=224)
-   -   WTB: tow/trailer harness (http://forums.pelicanparts.com/showthread.php?t=1068984)
Determined 08-01-2020 06:49 AM
I’ve got an 06 and I’m looking for the factory tow/trailer harness that is located behind the trunk right side panel connected to the Westfalia module going down to the trailer hitch. It’s the harness with the rectangular connector going to the hitch if anyone has one from a parts car. Thanks, Alex
RNajarian 08-04-2020 07:18 AM
Alex, here is a link to my write up on when I installed a factory tow setup in my Cayenne. You commented in this thread. I posted the link below in case you forgot.
I have a whole section on the harness. At the time I bought it used and later regretted not buying new from our host.
http://forums.pelicanparts.com/porsche-cayenne-macan-forum/792114-factory-tow-module-curt-trailer-hitch-installed-440-a.html
Determined 08-04-2020 02:30 PM
Awesome! Thank you kindly for your time and support. I’ll order the new harness, I hope the Westfalia I bought is the later version not needing programming.
Determined 08-24-2020 04:18 PM
Just received my Pollak connectors and tested my system with a set of trailer tow lights, everything worked perfect! Next is to hook up the trailer and test it the braking, I have no doubt at this point that it will work great. Fun projects and thank you RNajarian for your help as well.
I won't be needing my P3 Tekonsha now, I'm ok with that!
RNajarian 08-24-2020 05:41 PM
My pleasure ! It’s a pleasure to help someone out.
Congrats on your success !!
