Go Back   Pelican Parts Forums > Porsche Forums > Porsche Cayenne & Macan Forum
Broken Intake Manifold Bolt
Rear driver-side manifold bolt broken in half. I see that this has happened to others and I'm trying to figure out the best method to remove the bolt.
Old 06-04-2021, 02:28 PM
Definitely not a fun place to find yourself, especially on the rear most bolt... if welding a nut on the top of the remaining bolt is not an option, you can use a screw extractor and hopefully get it removed.
Old 06-04-2021, 03:56 PM
I’ve had to sand the remaining bolt with coarse paper or a Dremel then JB welded it to a sacrificial socket filled with JB weld, snug fit. Let it cure overnight, don’t drive it, then use a small ratchet and extension to remove. The bolt came out, trash the bolt/socket or keep it as a memory. Good Luck!
Its easier asking dumb questions than fixing dumb mistakes
1974 Porsche 911 Coupe, RSR Project
1976 Porsche 911 Targa, Black
1986 Porsche 911 Carrera, Black
2006 Porsche Cayenne S, Black
Old 06-08-2021, 04:01 PM
