E3 Cayenne S/GTS Product Suite
Fabspeed's Sport Catalytic Converters replace the restrictive factory cats with high-performance German-imported 200-cell HJS catalytic converters for significantly improved performance and sound. The Cayenne's factory cat-back exhaust has a very free flowing design when the valves are open so the only way to gain more sound and power is to change out the factory catalytic converters. HJS Sport Cats flow extremely well, flowing at 93 - 95% the rate of a straight pipe. Fabspeed Motorsport invested a lot of time and resources into developing the best possible downpipes and we're now proud to offer you this latest and greatest solution. Fabspeed Motorsport is the world's authority for aftermarket Lamborghini performance.
https://www.google.com/url?sa=i&url=...AAAAAdAAAAABAD SOUND: Aside from the factory catalytic converters, the E3 Cayenne GTS / Turbo has an extremely free flowing exhaust. So the best way to get more sound out of your Cayenne is to replace the factory catalytic converters. These Sport Cats will make your Cayenne sound much more aggressive. It really brings out the V8 sound from the 4.0L powerplant. Pops, bangs and crackles will be much louder and sharper. Best of all, there is no interior drone whatsoever. POWER: Get awesome bolt on power gains from your Cayenne GTS / Turbo with these Sport Cats. We saw max gains of 22 whp and 21 ft/lbs of torque. These Gains are carried throughout the entire RPM range for power you can feel in the seat of your pants. Peak power is also up 12 whp and 4 ft/lbs of torque! FEATURES: Fits all Porsche E3 Cayenne GTS / Turbo Vehichles (2019+) The largest catalytic converter that will fit the application German Imported HJS 200 Cell High Flow Catalytic Converters Saves 6 lbs / 2.7 KGs compared to the factory Catalytic Converters Adds 22 WHP and 21 ft/lbs of torque The most effective Urus exhaust modification No Check Engine Light Guaranteed Constructed from mandrel bent T304L stainless steel Simple DIY (Do-It-Yourself) bolt-on installation, no cutting or welding required All Fabspeed performance products are backed by the Fabspeed Lifetime Warranty |
Listen to how much of a difference just our high flow catalytic converters make on this 2020 Cayenne GTS Coupe. The GTS and Turbo models both share the 4.0L twin-turbo engine.
https://www.youtube.com/watch?v=TKFznzCEnfY |
Happy to update the community with some dynographs!
Our Sport Competition Performance Package will totally wake up your Cayenne GTS / Turbo and transform both the sound and driving characteristics. XperTune Performance software upgrade improves horsepower, torque, and driving characteristics by reprogramming various sensor inputs, air/fuel ratios, and boost pressure. Achieve excellent power from the Porsche 4.0L Twin Turbo V8 without sacrificing driveability or reliability by optimizing the engine's performance. FEATURES: Fits all Porsche E3 Cayenne GTS / Turbo Vehicles (2019+) On the GTS we saw huge gains of 203 WHP and 179 ft/lbs of TQ Lifetime BMC filters are washable and re-oilable Extra large German imported HJS catalytic converters specifically fitted for this model to maximize performance and flow, while maintaining durability Simple and direct bolt-on replacement for the stock ceramic restrictive catalytic converters Guaranteed No Check Engine Light. Fabspeed Motorsport USA is HJS Germany's exclusive importer and North American distributor so you will only get legitimate HJS catalytic converters when you buy from Fabspeed Motorsport. Upgrade the tune at no charge over the life of the car. Can be flashed back to stock when you would like at any time. NOTES This upgrade requires you to send us your ECU for re-programming. You will be emailed a download link with detailed instructions after adding this to your cart and checking out. You must fill out and include a copy of the ECU Information form along with your ECU upon sending it in. Please contact us if you need to send the form in any other manner. Fabspeed Motorsport saves your stock/factory ECU settings so that you can revert your vehicle back to stock settings at any time. http://forums.pelicanparts.com/uploa...1622565711.png |
| All times are GMT -8. The time now is 08:27 PM. |
