-   Porsche Cayenne & Macan Forum (http://forums.pelicanparts.com/forumdisplay.php?f=224)
-   -   Fan blower keeps running when car is off (http://forums.pelicanparts.com/showthread.php?t=1096063)
milt421 06-18-2021 12:20 PM
Help, please? '06 Cayenne S fan blower continues to run when the (1) in the OFF position and (2) when the engine is turned-off and the key is removed... any insights?
Thanks!
honerboys 06-19-2021 09:02 AM
are you talking about the electric engine cooling fan under the hood? - it will continue to run after car is shut off until it cools down the coolant in the radiator - there is a sensor that monitors that temperature - sounds normal - usually will only run about 1-2 minutes or so
island911 06-25-2021 11:08 PM
If you are talking about the cabin fan you will want to replace the fan-speed resistor/regulator.
https://www.pelicanparts.com/techarticles/Porsche-Cayenne/35-ELEC-HVAC_Blower_Fan_and_Regulator_Replacement/35-ELEC-HVAC_Blower_Fan_and_Regulator_Replacement.htm
