-   Porsche Cayenne & Macan Forum (http://forums.pelicanparts.com/forumdisplay.php?f=224)
-   -   2008 Cayenne Window Regulator replacement problems (http://forums.pelicanparts.com/showthread.php?t=1118780)
mhariush 05-13-2022 10:12 AM
hey guys
I just replaced the window regulator on my 2008 Cayenne, and it was a PITA. With the new regulator riveted in place, the window moves up and down when the frame is out of the car.*
Put the frame back in the car and I can't seem to manually move the window. But maybe that's normal.
I have attached the window motor but it doesn't move the window much. It enganges and moves the cable a little, but stops, like its at the end of its run? Or is something obstructing it? Do I need to adjust something on the motor or the window regulator prior to installation?*
I'm a little stumped here.
fintstone 05-15-2022 11:07 PM
It seems like when I did mine, I had to make sure that the window position and the motor matched...were both all the way up or down (both the motor and the window) when I installed it.
mhariush 05-16-2022 11:49 AM
the fix was to install with the window up, at least for. And remember to insert the window into the track on both sides! I did not do that the first time,
fintstone 05-16-2022 12:52 PM
Great! Glad you got it fixed. That is a pretty challenging job.
mhariush 08-06-2023 10:10 AM
Well, that didn't last long.
So now I have purchased an OE window regulator (VW) and I'm wondering if I need to replace my motor again. The Wire seems to have made a bit of a number on the gasket and maybe chewed a little on the teeth. But it could also just be metal and grease stuck in there.
http://forums.pelicanparts.com/uploa...1691341199.jpg
What do you guys think? Replace the motor (again)? Or is it going to be fine as is...
And any thoughts on why this happened again? Was the aftermarket (non OEM
