-   Porsche Cayenne & Macan Forum (http://forums.pelicanparts.com/forumdisplay.php?f=224)
-   -   Clear side markers install (http://forums.pelicanparts.com/showthread.php?t=435301)
stealthn 10-13-2008 07:19 AM
Hi,
I thought I would try to keep this forum active, so I'm posting pics of the clear marker install. It's a bit tricky but easy enough, I got the info on another forum. Not much to mod while still under warranty :(
http://forums.pelicanparts.com/uploa...1223907515.jpg
http://forums.pelicanparts.com/uploa...1223907526.jpg
Looks much better with Silver....
island911 05-28-2009 02:06 PM
So, did you take the bumper off to get to those?
looks great btw. ...but you know that already.;)
stealthn 05-28-2009 02:17 PM
No you go in through the wheel well, but really tiny hands would help ( you should've seen the cuts on mine). Best tool I go to do the job was a flexible screw driver extension.
island911 05-28-2009 02:30 PM
Thanks.
Did you just pry back the wheel well cover (removing just a few screws in the area) or did you completely loosen (and/or remove) the wheel well cover?
ChkbookMechanic 05-28-2009 02:53 PM
Looks good.. I've been debating doing this, but then I look at my 911 and realize I shouldn't even think about modifying the Cayenne until I clean up the backlog of 911 parts in my garage.
stealthn 05-28-2009 04:30 PM
There's some detailed instructions out there, but in a nutshell; I undid about 6-8 screws then pulled back the inner wheel well cover to expose the light. It has a screw right there to undo but the other one further in to the front is a bugger to get at (hence the flexible head screw driver).
When putting the new one on do the nasty screw first, then the easy one. Simple 30 minute, 5 beer job :Dhttp://forums.pelicanparts.com/uploa...1243553430.jpg
http://forums.pelicanparts.com/uploa...1243553442.jpg
