-   Porsche Cayenne & Macan Forum (http://forums.pelicanparts.com/forumdisplay.php?f=224)
-   -   Cayenne Oil Change (http://forums.pelicanparts.com/showthread.php?t=476572)
jgparker 05-26-2009 04:55 PM
Cayenne Oil Change
Hi all,
It's been a while. Call me dense, but how do you change the oil on a Cayenne? I just bought a 2004 S to tow my 911 to the track and I can't find a drain plug. Do you have to suck it out of the dipstick? I did a search and didn't find a how to.
Also, has anyone installed a trailer hitch on one? I hear you can't do it without having a dealer change the programming.
Thanks,
JP
http://forums.pelicanparts.com/uploa...1243382056.jpg
JHoffman 05-27-2009 04:25 PM
You need to remove the under trays. First you need to remove the brake ducts on each side they are the phillips screws. Then remove the 10 mm bolts for the tray. Remove both the drain plugs (8mm hex) and then remove the filter. Let it all drain to a drip and replace all the seals.
