Go Back   Pelican Parts Forums > Porsche Forums > Porsche Cayenne & Macan Forum
Wiring Diagram
Hi Everyone
Can someone please assist me by telling me how and where one can get a wiring diagram for a Porsche Cayenne?
Please help, as I am argently seeking for one.
Old 06-17-2009, 12:59 PM
It'll be legen-waitforit
stealthn's Avatar
Sorry Porsche is the only place I know of right now.
What are you trying to fix/do?
Bob James
06 Cayman S - Money Penny
18 Macan GTS
Old 06-17-2009, 06:10 PM
Thanks for th reply.
Do they provide the wiring diagram?
Most of electrical system of my Porsch Cayenne is failing... I think its a central problem because I did fix the stereo a while ago but it still fails to work now and than. Alot of other electtrical parts too!!!
Once again thank you for you help.
Old 06-20-2009, 01:00 PM
Information Junky
island911's Avatar
That's weird. What exactly did you 'fix' when you "fix the stereo'?
Sounds like something didn't get plugged back in properly.
Old 06-20-2009, 02:59 PM
Send a message via AIM to JHoffman Send a message via Skype™ to JHoffman
you will need to scan first to make life a lot easier. If multiple stuff is not working sounds like a CU is bad.
Old 06-20-2009, 07:14 PM
My biggest problem is that it does not start.
The key does not even turn and the stering wheel is locked and does not unlock too. There is no power on the desh board. I changed the battery and checked all the fuse and they all okay but there is no power inside the car.
Old 06-23-2009, 10:44 AM
Information Junky
island911's Avatar
I don't believe that a wiring diagram is what you need.
start probing the system.
Old 06-25-2009, 07:46 PM
do a voltage drop on the ground side of the battery. Did it just happen? Does anything work(interior lights, headlights, cig lighter?)
Old 06-30-2009, 07:03 PM
did you press the reset button after you exchanged your battery
Old 08-04-2009, 01:57 PM
