Did you see what it takes to change the starter
The starter is under the fuel injection and the cooling tubes in the center of the Vee..thats got to be some hours labor.
Bruce |
Yes it is.
Fortunately, I have only replaced them after coolant tubes have puked coolant into starters. Failing without the influence of coolant, not very common. |
![]() I can see it..eventually. Yes, coolant leakage from the plastic pipes does tend to damage the starter.
From November 2012; Precision Porsche Specialist Sussex UK, +44 (0)1825-721-205 2001-2012 Gerber Motorsport Inc. 206-352-6911 07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red 08.16.09 1999 Kawasaki ZRX1100. Green. |
Information Junky
Thanks for the pic, Mark!
btw, the plastic pipes in question are where that aluminum casting of three are, right? (we're looking at the updated version?)
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
Yes, that is a Cayenne we had to update.
Underneath the aluminum casting is another main pipe that requires replacing too.
before
![]() after
1980 911SC #99 track car, 993 3.6, 50 PMO's 2019 Ford F150 da dragger 2015 MB SL400 wifey DD 2008 E93 M3 DD 2007 E60 530 wifey winter beater |
