-   Porsche Cayenne & Macan Forum (http://forums.pelicanparts.com/forumdisplay.php?f=224)
-   -   Did you see what it takes to change the starter (http://forums.pelicanparts.com/showthread.php?t=539272)
Flat6pac 04-26-2010 06:21 PM
The starter is under the fuel injection and the cooling tubes in the center of the Vee..thats got to be some hours labor.
Bruce
Jamikest 04-27-2010 05:20 PM
Yes it is.
Fortunately, I have only replaced them after coolant tubes have puked coolant into starters.
Failing without the influence of coolant, not very common.
Britwrench 04-30-2010 05:47 PM
http://forums.pelicanparts.com/uploa...1272674771.jpg
I can see it..eventually.
Yes, coolant leakage from the plastic pipes does tend to damage the starter.
island911 05-01-2010 07:43 PM
Thanks for the pic, Mark!
btw, the plastic pipes in question are where that aluminum casting of three are, right? (we're looking at the updated version?)
Britwrench 05-02-2010 09:56 AM
Yes, that is a Cayenne we had to update.
Underneath the aluminum casting is another main pipe that requires replacing too.
SCOTITUDE 05-02-2010 10:51 PM
before
http://forums.pelicanparts.com/uploa...1272865786.jpg
after
http://forums.pelicanparts.com/uploa...1272865814.jpg
