Go Back   Pelican Parts Forums > Porsche Forums > Porsche Cayenne & Macan Forum
goat's Avatar
Doing My First oil change.
Going to do my first oil change on my 05 Cayenne S.
Any tips? Special tools?
Oh and how long from start to finish.
Thanks Tim.
Tim.
1988 911 Carrera. Silver.
1973 914 Metalic Blue.
2012 Cayenne S
Old 04-11-2012, 12:17 PM
Information Junky
island911's Avatar
http://forums.pelicanparts.com/porsche-cayenne/504454-own-work-04-05-06-a.html
Old 04-11-2012, 02:45 PM
It'll be legen-waitforit
stealthn's Avatar
Got to do mine soon too. Do you have any pictures of the drain plugs location wise?
Cheers Bob
Bob James
06 Cayman S - Money Penny
18 Macan GTS
Old 04-15-2012, 06:11 AM
goat's Avatar
I meant to take photos and journal the event, but it turned into a rush job, the car was packed and had to leave the house at 5am!.
Few tips though:
1. When taking off the filter loosen then slip a big zip lock bag over it then remove. The oil gushes out, so the bag catches all.
Slip the filter onto the exposed tube then screw the filter housing onto the threads.
Removing and reinstalling the two bottom plastic plates took most of the time.
I did some cleaning while under there.
So the whole job took me 2 hours!
Good luck Bob!
Tim.
2012 Cayenne S
Old 04-16-2012, 10:57 AM
Information Junky
island911's Avatar
Cheers Bob
some pict's here. 2004 Cayenne 60k service | RennsportKC
Old 04-16-2012, 04:14 PM
stealthn's Avatar
Thanks island, hey my ashtray is stuck too. It's a coin holder though . Hw do you get the silver faceplate off around the cluster?
Bob James
18 Macan GTS
Old 04-21-2012, 06:25 AM
Information Junky
island911's Avatar
silver faceplate: I've never had mine off, so I don't know. (I'm guessing that it's press in straight / pulls out straight ...d/k)
Old 04-21-2012, 12:53 PM
stealthn's Avatar
What size is the torx!?!
I put in a 50 it felt a little loose, one turn and i stripped the nut DAMIt!
Let me know the size if it's 50 the dealer put it in way too tight
Cheers Bob
Bob James
18 Macan GTS
Old 04-21-2012, 04:40 PM
Information Junky
island911's Avatar
I took pict's last oil change...
Tools needed (8mm, #2 Phil, 10mm socket . . . cordless drive)
Notes
Undo rear-screws before dropping front of rear cover.
Old 04-25-2012, 12:47 PM
stealthn's Avatar
WHAT!!
So it's not a Torx?!
DAMIT - My fault, I thought I read Torx somewhere no wonder it didn't work. I have an 8mm Allen key
Looks like I'll try again
Bob James
18 Macan GTS
Old 04-27-2012, 02:49 PM
Information Junky
island911's Avatar
Well mine is not Torx. ...but yeah, you might want to check that.
Old 04-27-2012, 06:53 PM
