-   Porsche Cayenne & Macan Forum (http://forums.pelicanparts.com/forumdisplay.php?f=224)
-   -   2004 Cayenne-S misfire cylinder 1, 3, 8 (http://forums.pelicanparts.com/showthread.php?t=704924)
paulwu 09-13-2012 10:43 AM
Hello all,
Need your guys help here. The 04 Cayenne-S was running fine but all sudden losing power while doing a parking with trailer. Idle very rough, low and smell fuel from the exhaust.
Got the code of p0300, p0301, p0303, p0308 they are the multiple misfire and cylinder 1, 3 & 8 misfire.
What I have done already below in sequence:
1. Changed all 8 spark plugs new
2. Changed all Beru coils new.
3. Changed new battery.
4. Disconnect the coil connector 1 & 3 while idling; the same rough shaking; guess there were no spark or signal
5. Swapped camshaft position sensors bank1 and bank 2; was guessing it could be one of CPS bad.
6. Checked each coil connector and power; all are fine.
All resulting in the same things; erased the codes each time but came out the same.
What else can be?
Being doing many research and there are things found that could be; but not sure how to check:
-DME?
-Fuel pump? not enough fuel pressure...but why only 3 cylinders misfire?
-Compression test..can't image why and suddenly if I have 3 cylinders down?
Any input will be great appreciated!
Regards,
Paul
island911 09-15-2012 05:51 PM
scratching head....
If it were fuel pressure I would think that misfires would be all over the map.
I would check the injector leads for signal. ...check connections...?
fintstone 09-16-2012 10:17 AM
Vacuum/air leak of some sort.
paulwu 09-17-2012 07:15 AM
Thanks for the info! I got the car running after rev the engine 5k 3-4 times then suddenly it is back. I believe it is the fuel issue; either fuel pump or injectors blocked. will keep checking.
ninelevenick 09-19-2012 05:37 PM
Did you clean the mass air flow sensors? Have you recently used a fuel injection treatment?
paulwu 09-21-2012 05:23 PM
I didn't clean the MAFs; but since it suddenly return to normal now I am driving it full tank with fuel injectors cleaning treatment in it. Hopefully it was just the bad injection. So far being 4 days and running smoothly..just feel much less power with the addictive.
jfort 04-08-2016 03:29 PM
04 S. 184K miles. New plugs. New fuels pumps. Missing. Code misfire cylinder 8. Just replaced all coils. Still rough. Same code after reset. Any ideas?
