Next big coolant leak for the V8's
The next big coolant leak for the S and T's will be this coolant T located between the engine and firewall. I don't have any other details other than they probably crimped the clamps to tight and weakened the T.
CaveVan
This has been pretty well documented and has become part of the coolant pipe swap for most people since its a bit easier to get to with the intake off.
Hell Belcho
Dont even attempt it without removing the intake. You'll end up breaking even more plastic lines trying to replace that T fitting.
Saved by the buoyancy of citrus. |
Silly cheap easy fixes for the Manufacturer.
Not so much for the Purchaser. Confuses me about quality on the German side.
Formerly from ratslist. AMG E 55..2002. Lotus Esprit SE. 1990 |
yes, mine just let go last night! I did the coolant pipe upgrade two years ago , but not this pipe. Can it be done without taking off the intake manifold, please say yes!
Mike Platt Car issues under restoration: 1977 911 targa, 1962 356b, 1983 944. Drivers: Mini JCW countryman, 1992 Sunburst yellow Miata, 2009 Honda Ridgeline |
Courtesy of PORSCHE OF NORTH AMERICA, INC. 1. Drain cooling system. --> 193817 Draining and filling coolant (includes bleeding) 2. Remove intake-air distributor. Refer to 24 46 19 Removing and installing intake-air distributor - as of MY 2003 (Cayenne S TIP, Cayenne S MAN, Cayenne Turbo, Cayenne Turbo S, Cayenne S TIO Titan) . INFORMATION Component overview Of course that section is like 20 pages.
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
arghhh! well at least i won't need to drain cooling system, as it drained itself when the hose went
I'm going in this weekend! Whoo Hooo. I almost forgot how much fun it was doing the coolant pipes.
My pipes were changed by the dealer and they didn't change the T.
After a chat with my mechanic a bit of good news is, as the OP mentioned, the t was too crimped . With normal tightening it should be fine .
Hell Belcho
It isnt that bad. I can typically do it in under 5 hours including changing the starter. An air saw and poly grease help quite a bit. The biggest pain is getting the bits of plastic out of the existing aluminum fittings. PM me if you have any questions.
Any thoughts if I need to stick with the Porsche coolant? Its 85 miles to the dealer and if I can use some other brand it may help. Otherwise the job is moving along. Getting ready to dive into the firewall area to get that darned T out
We need to get someone like LN engineering, or Elephant, or somebody clever like that to machine a steel T.
Hell Belcho
Or you could just go down to your local hardware store..
Hell Belcho
I only use the Porsche coolant.
The NAPA store here stated that the Zerex DEX-COOL is the stuff to use. I don't remember the cost but it is probably under $15/Gal.
