Go Back   Pelican Parts Forums > Porsche Forums > Porsche Cayenne & Macan Forum
Carl Fausett
Carl Fausett's Avatar
We can repair Cayenne blocks
We have a process now where we know exactly how to repair the Cayenne engine affected with piston and cylinder scuffing.
We will bore your block from between 0.010" to 0.020" to remove the gouges, plate it with NiCom (Nikasil) back to near-original dimensions, have custom Arias forged pistons made to our specs, and supply them to you with new piston rings designed for Nikasil.
Our pistons are specially manufactured to fit on the stock rods. All you need is an engine gasket set, a set of bearings, and put it together!
In addition to a SUV-saving repair, these forged pistons are much stronger than the stock cast pistons, and the Nikasil-over-Alusil composite is tough-as-nails for your block!
More information here:
928 Motorsports - Engine Block Repair Kit for the Porsche® Cayenne
Carl Fausett
Member SAE
Phone: 920-485-0928
Email: carl@928motorsports.com
Old 07-13-2015, 12:02 PM
Carl Fausett
A few more pictures...
Carl Fausett
Member SAE
Phone: 920-485-0928
Old 07-14-2015, 09:13 AM
Information Junky
island911's Avatar
what the . .
How does that carnage happen?
With piston and cylinder scuffing fully around the circumference, it looks like someone filled the case with 40-wt sand.
Old 07-18-2015, 12:21 PM
How does this happen, low oil pressure or excessive heat?
Its easier asking dumb questions than fixing dumb mistakes
1974 Porsche 911 Coupe, RSR Project
1976 Porsche 911 Targa, Black
1986 Porsche 911 Carrera, Black
2006 Porsche Cayenne S, Black
Old 07-19-2015, 04:20 PM
Carl Fausett
It was first thought to be sulpher in the fuel. Then it was thought to be found in only Cayennes with cast, not forged pistons. Some think it has to do where the car is kept (cold vs hot)
The official line now from Porsche technical Bulletin is it was caused by a boring/honing process that left the cylinders prone to distortion. They have corrected the problem as of about 2012...
That said - not all 2002-2010 Cayennes have this problem. But it is common enough that we get a lot of calls for it.
Carl Fausett
Member SAE
Phone: 920-485-0928
Old 07-20-2015, 06:36 AM
Proprietoristicly Refined
John_AZ's Avatar
Carl,
A major thank you for the post.
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 08-10-2015, 04:43 PM
I can to do your shop to fix the fins!
Download Free Games -> taigamemienphihay.net
Old 08-28-2015, 11:59 PM
