Go Back   Pelican Parts Forums > Porsche Forums > Porsche Cayenne & Macan Forum
dzlndan's Avatar
Is there no fuel filter??
I had a few occasions where I had a definite miss. Once when I was on the highway about 55 mph and one other time in town, probably around 35-40 mph. It never threw a code. I did not throw it on the Durametric yet. It hasn't happened again for over a week probably several hundred miles. I'm thinking I probably had a sticky injector maybe some dirt in the gas?? Anyway I figured I would just replace the fuel filter. But I can't seem to find any listings on the internet for a fuel filter for my 06CTTS. I can't believe there is no fuel filter? Is this true?
Old 10-29-2014, 09:09 PM
Filters are in the tank. "Lifetime filters" Yeah right.
You may want to check your fuel pressure and research the fuel pump threads.
2 fuel pumps in the tank:-( one on each side. Left side is primary and right the secondary pump. As I understand it if the left pump starts to fail the right does not take over, it's there for fuel transfer and high fuel demand needs.
Mine '05 would die and most of the time re-start within a minute or 2. eventually it got so bad I barely made it home.
There are 2 fuses in the panel near the left windshield wiper. 14 and 15? My Owners manual listed them. If I pulled the primary fuse I got fuel pressure after start and could drive it.
I took some pictures while doing mine. if you end up doing yours and pics might help reply here and i'll post them.
Lots of dust and grit on top the tank openings. Clean really good as you open things up. NO SPARKS! Ground everything, Gas fires are nasty
'99 Guard's Red C4 ; 2005 Cayenne Turbo, 09 Aston Martin V8 Vantage
gone:
W8 SW
couple of Z-3 M's, couple of Lotus, Couple of MG's, Couple of Triumph's
Old 11-02-2014, 08:52 PM
DSPTurtle's Avatar
And the tank is under the rear seat. One fuel pump/filter on one side, the others on the other side. You may have to cut the carpet to see the access holes or yours may have already been cut/marked at the factory.
Old 11-08-2014, 09:13 AM
