Go Back   Pelican Parts Forums > Porsche Forums > Porsche Cayenne & Macan Forum
Porsche Cayenne 4.5 s leak into drivers footwell RHD
Hi all I really need some help I notice the carpet was wet in the drivers footwell, the foam had about 5 ltrs of water in it, I dried it out and began to investigate. So far I have:
1. Checked the drains in the wheel arches are clear.
2. Checked the door and mirror seals.
3. Checked the rear wash pipe for damage.
4. No sunroof fitted so no drains to check.
5. Checked the AC drain.
6. Windscreen replaced and seal checked.
It still leaks but only during heavy constant rain. The bulkhead foam gets wet first, just behind the brake and accelerator pedals. I think it must be coming from some sort of bulkhead seal.
I would be really grateful if anyone knows what seals are in that area and how best to get access to :confusedthem, is it a dash out job! Or can I acces via the engine bay. Or am I looking in the wrong place thanks lee.
Old 12-10-2015, 04:31 PM
Tags
bulkhead , cayenne s , drivers footwell , leak
