-   Porsche Cayenne & Macan Forum (http://forums.pelicanparts.com/forumdisplay.php?f=224)
-   -   Driver side Door Alignment (http://forums.pelicanparts.com/showthread.php?t=886773)
Determined 10-12-2015 11:49 AM
Well, I noticed today my driver side door is leaning downward on my Cayenne S. Anyone have this issue and what was done? Thank you.
When I shut my door it takes a little more push to get it to close on it's own.
Determined 10-15-2015 01:32 PM
Let me ask this again in a different way:
Can the door be adjusted through the hinges or do I need to replace something? If adjustable, can someone please guide on the do's and don'ts.
Thanks.
MrFlip 10-30-2015 12:13 AM
Your not the only one with that problem! I've had that problem for a while now too and I'm going to dissect it this Saturday and will provide photos and hopefully an answer to our dilemma.
island911 11-01-2015 09:52 AM
Mine was a bit saggy, so I shimmed behind the bottom hinge to bring it up.
Determined 11-08-2015 10:21 PM
Hi guys, any update on a fix, I understand the shim approach but I'd like to know MrFlip's outcome. Pictures would be great of any work done.
My next project is addressing the fuel smell by replacing the fuel filter/cover and both fuel pumps.
968rz 11-09-2015 10:45 AM
The doors can be adjusted at the hinge but outcome depends on the cause.
Garrett 11-22-2015 11:34 AM
It's not uncommon to require shimming at some point... for some reason. You can either buy some shims from the dealer, or just use regular old washers. I used washers and it worked PERFECTLY for both front doors that required it on my 08 GTS. All you need to do is undo the lower hinge on the side of the door itself, and place washers of whatever thickness between the door and hinge mount plate. Use washers that are the proper thickness needed to line the door up just right - just try thin ones first, see how it shuts, then thicker, etc. Pretty easy to do; takes just a few minutes. Worth doing so you don't kill the weatherstripping and require its replacement.
Determined 11-23-2015 01:14 PM
Thank you Garrett, I'll give it a shot. How did you support the door without flexing or damaging the bottom door seal? Thanks.
Garrett 11-23-2015 07:26 PM
You bet... I used a jack on the flat part of the underside of the door (not the outer edge sheet metal).
Determined 11-26-2015 12:54 AM
Great, thanks again.
island911 12-08-2015 10:05 PM
You can gauge the needed shim thickness by measuring the existing offset (trim line mismatch) and then use a shim about half that thickness. --the exact ratio is the distance between the hinges vs the length of the door. ..maybe it's 2/3.
Determined 12-10-2015 01:18 AM
Thank you island911, I appreciate the advice, I'm tackling this project over the holidays.
Best Regards and Happy Holidays to Everyone!
