-   Porsche Cayenne & Macan Forum (http://forums.pelicanparts.com/forumdisplay.php?f=224)
-   -   08-10 Cruise Control DIY (http://forums.pelicanparts.com/showthread.php?t=894876)
wopdeeze 12-13-2015 10:37 PM
This is not a full write up, as you can find pretty much anywhere on the internet about installing the switch on the steering column. For the 2008-2010 Cayenne once you install the switch your next step is going to the dealership to enable cruise control in the DME. no additional wires to install. You can pull the switch from any Touraeg or Cayenne and that is it. Hope this helps someone out because i searched high and low for an absolute answer. My install was done on a 2008 GTS.
