2004 Cayenne turbo
i just brought this Porsche and two days later the airbag light came on. Dealer got a code 1218 passenger side airbag he hasnt repair it. then i found coolant leaking. i only had the car for two weeks. what can i do? What should I do? please help people.
Are you DIY savvy that you could fix the coolant leak yourself? Where is it leaking from? Otherwise, you can go to an independent Porsche shop and have them do the repairs, which will most likely cost you less than a trip to the dealer. You can use this site HERE to help you find shops near your location. Good luck. Hope you get all of this figured out.
The airbag code is a very common issue. The wiring under the seat is faulty. Look at this thread it is very informative
http://forums.pelicanparts.com/porsche-cayenne/529043-side-airbag-fault-warning.html |
Wayne |
Glad you got it all fixed up, Wayne! Have a great weekend.
| All times are GMT -8. The time now is 11:02 AM. |
