Heater core replacement help needed
How do you replace a heater core on 2006 Porsche Cayenne Turbo? Can any provide any help?
Djordan867,
The heater core is removed from the under the drivers side dashboard. It is located right in the center of the vehicle above the transmission tunnel underneath the dashboard. The relay carrier, Immob CU, and Electrical CU must be removed, hidden behind the drivers side lower dash panels. Hope that helps! |
