-   Porsche Cayenne & Macan Forum (http://forums.pelicanparts.com/forumdisplay.php?f=224)
-   -   Front Door Drupe Adjustment (http://forums.pelicanparts.com/showthread.php?t=939544)
Yagura6120 12-17-2016 07:24 AM
Does anyone knows the procedure how to adjust Door drupes?
I know the way to insert shim at lower bolt for hinge but unfortunately the bolt is too tight and gave up to loose the bolt. I think the adjustment can be done for the hinge main body side bolt but not sure. It is not technical item but need to fix it.
Yagura6120 03-13-2017 07:07 PM
:) I tried easy way to compensate Door droop.
Juck up Door end bottom very carefully using wood chip and keep the height slightly higher than it should be. Then removed the tool.
It worked fine for me and still looks ok after several months.:cool:
Determined 03-27-2017 07:11 PM
I have the same problem, can someone post pictures and maybe a short write up in this? Alex
