Go Back   Pelican Parts Forums > Porsche Forums > Porsche Cayenne & Macan Forum
Mike (guest)
Guest
Posts: n/a
Nick, in answer to your question on crank or no crank, it's "no crank" the first couple of tries. Also, I've found that if I pump the brake pedal 3 times before turning the key, it will start, usually the first time.
This post was auto-generated based upon a question asked on our tech article page here: Porsche Cayenne Diagnosing Brake Booster and Master Cylinder Problems | 2003-2008 | Pelican Parts DIY Maintenance Article
Old 02-07-2017, 01:23 PM
If your Cayenne is one of the ones that requires a brake pedal to be pressed to start, you probably have an intermittent fault with one of the switches. Check out this article for more information: http://www.pelicanparts.com/techarticles/Porsche-Cayenne/37-ELEC-Brake_Light_Switch_Replacement/37-ELEC-Brake_Light_Switch_Replacement.htm ] http://www.pelicanparts.com/techarticles/Porsche-Cayenne/37-ELEC-Brake_Light_Switch_Replacement/37-ELEC-Brake_Light_Switch_Replacement.htm [/url]
- Casey
