Go Back   Pelican Parts Forums > Porsche Forums > Porsche Cayenne & Macan Forum
mhariush's Avatar
Higher mileage thoughts 160k+
Hey
I'm trying to read up on old threads about reliability for these cars. But some of the threads are getting older
I'm looking for a daily driver and there are a few cheap options out there with 160,000-180,000 miles on the clock.
In addition to coils, coolant lines and the shaft. Anything that tends to keep popping up at these mileage ranges? Wheel bearing or other stuff?
Seems a lot of people decide to offload their cars around this mark...
Current: 87 944S Black/Black, 89 944 Turbo S ANDIAL White/Burgundy, 78 924 Black/Black, 17 Cayenne S, 03 Turbo X50 Aero
instagram @mhariush http://stores.ebay.com/Techniker-Parts/
Old 01-22-2017, 07:26 PM
Other than the three issues already noted add sunroof drains and the rear bushings on the front control arms. Upgrade to the Turbo S arms when a vibration at 40-80 mph is noticed that balancing the tires can't get rid of. The only way to really check the bushings is to use a load arm like this.
Suspension Wear Indicator - Mueller-Kueps LP
Old 01-24-2017, 07:23 AM
I think a well sorted, regularly oil changed Cayenne is of great value for less than $10k. Plus I like the look of the older model especially with 19' or 20' inch rims. I have an 08 and in addition to drive shafts (vendor in FL has used shafts) it is generally a very reliable truck.
I had some idling issue a few years ago at 120k miles and had an apparent cracked cam something that was a fairly big repair around $1,000. The brakes wear out a lot faster than normal SUV's as these are heavy but safe vehicles, a blower motor for AC/heat needed to be replaced and now more recently I have a "fuel pressure sensor" code error that is being replaced but the part is only around $100.00
I am now at 162k and I think the vehicle still runs great. I had asked my mechanic if he thought I should dump it after losing power and stalling a few times but if it is just this "fuel pressure sensor" and it runs for another few years it will earn best vehicle ever honors.
Regards,
Matt
Matt S
Montclair, NJ
68 911 Sunroof Coupe - Sold
89 911 25th Anniversary Model Coupe
Old 01-24-2017, 12:55 PM
Hi everyone. I am a new member and I would like to say that this forum is a great one.
Be unique in what you do
Old 01-26-2017, 05:03 AM
Ditto!
Old 01-26-2017, 09:10 AM
Agree with Surf. I have a Cayenne with 200k and it runs great. Now in the market for a convertible of some sort to take to the beach. Any thoughts?
Old 01-26-2017, 09:27 AM
Hey BeachNCars, thanks....
I feel like the Porsche 911's are fairly to fully valued. They are great and really well worth it but are priced as such now. So, whats next on appreciation potential?
If you don't mind a go kart little 2.0 FI Engine, I think the early 80's Fiat Spiders eventually start to appreciate. You can pick up a beach cruiser for 4k that needs work and cosmetic issues....up to to 9k in pristine condition...Same Pininfarina factory as Ferrari. There were so many imported to US (80% of market) they are still at bottom of depreciation scale and I think they eventually start to appreciate despite having reputation of FIAT "fix it again tony" back in day
Matt S
Montclair, NJ
Old 01-26-2017, 09:46 AM
Surf65 you sound like a very knowledgeable owner. I don't think I'd mind the 2.0 go kart, especially with the Pininfarina. I see you're in Jersey, I'm in the area as well. Any ideas where to look?
Old 01-26-2017, 02:08 PM
super9064's Avatar
Would you mind elaborating on the sunroof drains, and the fix. I've had mine at the dealer several times and they have not resolved the issue.
Thanx
Rob
Old 01-29-2017, 05:21 PM
More or less a plastic tube disconnects. If its just a sunroof, it's usually the A-pillar/above your head getting wet, sometimes the floor on the passenger side. Tube comes off the drain spout at the sunroof module. If its the panoramic roof the rears get plugged with dirt. If theres no sun/pano roof the gaskets for the roof rack rails leak.
Old 01-30-2017, 06:54 AM
I Love my 1990 944 S2 Cabriolet.
Gone but not forgotten: 1971 914 First Car (SOLD) | 1972 914 rust bucket (SOLD) | 1986 944 Turbo (Murdered by a Chevy Truck on the freeway)
Current lineup: 1990 944 S2 Cabriolet - Long term project | 1971 914 - Long term project #2 | 1971 914 - Driver
Old 01-31-2017, 08:19 PM
Porsche 944S Club Sport
guru944's Avatar
Send a message via AIM to guru944
My 184K Cayenne S is Awesome. Just did the Cardan Intermediate Driveshaft Support Bearing. Best vehicle i have ever had so far...
Guru944
2006 955 Cayenne S Titanium Series - Marine Blue, 1987 Porsche 944S Club Sport.
1987 Buick Turbo-T Lightweight "Great White", +500HP, TA49 Turbo.
http://www.blackbirdmotorsports.com, 944/951/968, 911 and 955/957 Performance Solutions.
Thank you Lord, for your Loving Kindness, Tender Mercy, and Grace. Only You are Faithful.
Old 02-04-2017, 07:04 PM
Double Trouble
targa911S's Avatar
These are going up as are all air cooled Porsches every day
I used to be addicted to the hokey pokey..........but I turned myself around..
75 914 1.8
2010 Cayenne base
Old 02-14-2017, 09:12 AM
