Go Back   Pelican Parts Forums > Porsche Forums > Porsche Cayenne & Macan Forum
2013 Diesel oil change at 40,000 miles
Well... it did not go that smoothly.
1. I used a new sump plug and copper ? crush washer from the kit and was not able to get a complete seal ... even after tightening again and switching to the original crush washer . There is maybe one drip per 15 minutes or so. Went to 22 ft-lb I also noticed that the oil was coming out just when I started to unscrew the original sump plug meaning it was not a close fit on the threads .
If the dealer uses the extraction method, this sump plug may be original from factory.
2. I could not get the top off the filter element cannister ... I as going to purchase a 32 mm socket as the wrench is only in 2 sides .. the spec says 26 ft-lb.
3. There seems to be a bracket missing connecting the filter cannister to the block .. see image . I think I saw it missing on an online video also. Do I ask the dealer if it is a spec. change ?
Added 7.5 liters of 5w-30 Mobil 1 ESP and checked with my dipstick and it looked good and the instrument cluster oil level registers full ... but takes some time to calibrate ? Normal ?
So I need to fix the small leak at the sump and get the new filer element in ... any ideas on this .
Thanks, Bob
Old 03-13-2017, 12:28 PM
Old 03-13-2017, 01:18 PM
