-   Porsche Cayenne & Macan Forum (http://forums.pelicanparts.com/forumdisplay.php?f=224)
-   -   Hybrid system fault (http://forums.pelicanparts.com/showthread.php?t=961582)
tuysombo 06-27-2017 05:53 PM
Hybrid system fault
Hi,
I have Cayenne 2012, having this DTC, P309D, Separating clutch actuator insufficient slip with open clutch (showing on the instrument as: hybrid system fault on the display)
Symptom: Hybrid message shown, this happen when high speed and des-aceleration from high speed of between 60-80km/h.
Replacement: I have replaced new separating clutch actuator hybrid.
- performing successfully clutch bleeding.
- Perform clutch adaptation.
-Check clutch disk and cover.
- Wiring.
I still have this problem still, pls advise.
J_C_M_L 08-16-2017 07:12 AM
Hi, tuysombo.
I'm having the exact problem as yours for my 2012 Hybrid, workshop used 2 weeks trying to fix it but in vain.
Burnt a hole replacing parts told by workshop but still couldn't resolve it.
Did you manage to resolve yours?
Mind to share?
Many thanks and God bless!
J_C_M_L 08-16-2017 07:15 AM
http://forums.pelicanparts.com/uploa...1502892895.JPG
