-   Porsche Cayenne & Macan Forum (http://forums.pelicanparts.com/forumdisplay.php?f=224)
-   -   04 Turbo Air Spring Replacement (http://forums.pelicanparts.com/showthread.php?t=961903)
andrewjt19 06-30-2017 05:27 PM
Anyone know how I can remove the air fitting from the air line? I'm installing a new air spring from Arnott and it says to remove the brass fitting from the air line so the line can be pressed into the new fitting in the new spring.
Follow the video at about 2:20....
https://youtu.be/I5VX3lSssGYhttps://uploads.tapatalk-cdn.com/201...7f38ebad36.jpghttps://uploads.tapatalk-cdn.com/201...d34ec19cda.jpg
Sent from my Nexus 6 using Tapatalk
island911 07-04-2017 08:46 PM
looks like you need to pull the compression fitting out first. - The small diameter brass bit.
