Alignment Question?
Ok. I am getting a slight pull to the right, so I am going to take the cayenne for a Four wheel alignment.
My question is. Does anyone has any number for camber numbers that work best, or toe in or out numbers? Or should I just leave it up to the techs. Thanks! |
If it's a good suspension shop, I'd leave it up to the techs, just my 2 cents... - I tried searching the forum for a thread on the Cayenne alignment but wasn't able to locate one. If you're looking for specs, try googling 'Cayenne Alignment Specs' - best of luck!
Yes I think I'll leave it to the techs. The Shop I am planning on going to uses a Hunter HawkEye Elite Alignment System? Sounds cool.
Did find these specs for others to look at not sure how helpful or not. http://forums.pelicanparts.com/uploa...1499979055.png http://forums.pelicanparts.com/uploa...1499979055.png |
| All times are GMT -8. The time now is 10:03 PM. |
