Porsche Crest Rennen Motorsports.com RARE Porsche Factory Tools
Serial Numbers available - please inquire regarding which ones you need to complete your set.
P286 - Repair Group 40; for changing stub axles
G50 - 8 piece set includes G40, G41, G42, G44, G47, G48, G49, G50
Werkz Nr. 258 Jstmas: 54.01, comes with block (part no. 9.52); differential tool for setting pinion depth
018 012 500 - 11 piece set with original case
VW388
P82
P286C - For checking steering knuckles; repair group 40
VW454 - Repair group 35, for pressing tapered bearing onto pinion shaft
P220 - Repair group 13; for measurement of intermediate shaft end play
VW202 - Repair group 13; removal of crankshaft gear
VW510 - Repair group 39; for installing final drive bearing in conjunction with tool VW295
P284 - Repair group 40; for checking steering arms
P221 - Repair group 13; for support of connecting rods during engine assembly
P351 - Repair group 37; for blocking transmission gears on the P201 engine assembly stand
P41 - Repair group 35; for installing bearing onto pinion shaft
P65 - Repair group 35; for removal of roller bearing on main shaft
P63 - Repair group 40; for removing inner bearing from stub axle
P68 - Repair group 35; for guiding selector forks while adjusting shift forks
P358 - Repair group 32; for installing large torque converter seal
P357 - Repair group 39; for measuring ring and pinion backlash (Sportomatic)
P259 - Repair group 39; for measuing ring and pinion backlash
P303 - Repair group 42; for R&R of coil springs in conjunction with tool VW 340
VW411
P366 - Repair group 34; for tensioning springs in gearbox housing
P234B - Repair group 23; for tensioning of injection pump belt
P358A - Repair group 37; installation of sealing ring (Sportomatic)
P259A - Repair group 39; for measuring ring and pinion backlash
P286D - Repair group 40; used with P286B with Bilstein shocks
P301B - Repair group 44; for height measurement of front axle (Hydropneumatic suspension)
P265C - Repair group 39; for installing output flange seal
P356B - Repair group 39; for holding axle flanges during R&R of stretch bolts
VW428A - Repair group 13; for guiding lock ring onto crankshaft
P17 - Repair group 13; for determining crankshaft end play with flywheel installed
P356 - Repair group 39; for holding axle flanges during R&R of stretch bolts
P373 - Repair group 30; for centering clutch disc (Sportomatic)
P230B - Repair group 23; for adjustment of idle speed (8mm)
P370 - Repair group 30; for centering clutch disc
P61 - Repair group 34; for installation of pinion shaft bearing race in transmission housing
VW385/25 - Repair group 39; used with VW385/1
P282 - Repair group 40; removal of steering gear drive pinion
P287 - Repair group 40; for installing rubber mount on transverse control
P284B - Repair group 40; for checking steering drop arm
P222 - Repair group 13; for support of timing chain during engine assembly
P55 - Repair group 35; for pressing intermediate plate onto main and pinion shafts
P233B - Repair group 23; for checking fuel pressure
P223
P254 - Repair group 34 and 39; for pressing operations
Prices do not include shipping. Offers encouraged. Pictures are available so please email for details.
Thanks,
Greg
Rennen Motorsports
http://www.rennenmotorsports.com
info@rennenmotorsports.com
(540) 381-5398
Old 05-29-2002, 07:38 PM
