Diecast Model Repair
Does anyone know of a source/company that repairs diecast model cars? I have a 1/18 Spark 911R that had the roll bar come loose. Spark are resin based with no opening parts/doors so I can't get in there to try and fix it. I contacted Spark by email some time ago and they were no help. Any suggestions would be appreciated.
If you have local hobby shop, maybe they have knowledge of local model builders / customers who maybe able to help out. There are a lot amateur model builders who can do some amazing stuff.
I think Spark are resin with only a few screw holding the top (body) and bottom (interior & chassis) together.
Once you remove all the screws, you can just lift off the body. You can then glue the roll bar back on. |
It does have four screws towards the front. I'll give it a shot. Thanks.
Taking the four screws out on the bottom did nothing to loosen the body from the lower portion. I guess I'll check locally with the hobby shops.
most likely some hidden screws then. Does it look like the exhaust system is a separate piece that could pop off easily? That may be a hiding place. Also, possibly in the wheel wells - not great because the wheels would have to be removed first...
I just look at mine, 90% sure there are 2 more screws behind the muffler, I did not take the 911r apart, but did took apart a 3.0rs, they are the same set up.
Thanks. I'll take a look when I get back home tomorrow.
