-   Porsche Engine Conversion Tech Forum (http://forums.pelicanparts.com/forumdisplay.php?f=28)
-   -   1972 Porsche 911 Outlaw Project (http://forums.pelicanparts.com/showthread.php?t=1021398)
Ryan_Cunningham 02-18-2019 03:06 PM
Good Evening All,
I recently took the plunge into 911 ownership and received the car today after looking for quite some time. I imagine a few of you saw the car listed recently on eBay or elsewhere but it was pretty much exactly what I was looking for - A cosmetically rough, older 911 with a solid mechanical base. This one just happened to have a 930 trans and ZZ4 small block Chevrolet engine. I'm sure that will offend a number on the forum but I've always loved the idea.
Regardless, I wanted to introduce myself properly and hope to periodically post updates on the progress of my car. I've had a number of toys over the past 10-15 years - A Dodge Viper, Chevrolet Corvette FRC, Ducati 1198, KTM RC8R, and a number of McDonnell Douglas F/A-18s. But I never spent any real time working on or modifying them, my work schedule didn't really allow much free time. But after an unforeseen medical issue has now caused me to shift careers, I've found that I have significantly more time (when it's not being consumed by my beautiful, year old daughter) and figured now was as good of a time as any to pursue a passion that'll allow me to learn a number of new skills while I get to work with my hands creating my 911 into exactly what I want her to be.
Here is a quick photo I snapped after getting out of the car for the first time - What a blast. Completely unlike any other vehicle I have experienced. Raw and completely connected to the car.
Feel free to ask any questions as I'll be asking more than my share here over the next several weeks, months, and probably years. http://forums.pelicanparts.com/uploa...1550531102.JPG
IS300 02-18-2019 05:06 PM
How about some more photos??
Ryan_Cunningham 02-19-2019 02:53 PM
The weather is suppose to be pretty bad the next several days so she's covered and put away. Here are a few that the seller sent to me as the car was getting loaded up. I don't have any interior pictures - It's pretty rough. The dash needs a complete restore/new pad, the headliner is pretty much gone, and there is no backseat or carpet. The thing that immediately needs changed is to lower the intake filter assembly. There is about an 1.5" spacer for some reason and I need to get it out of the way so I can install a grill in the ducktail for a significantly cleaner look.
A quick question if anyone knows - The tachometer isn't hooked up, I however have it in my possession. Is there a way I can test it to ensure it works before ordering the Tach Adapt kit that one of the Pelicans here created years back?
TACH-ADAPThttp://forums.pelicanparts.com/uploa...1550616767.JPG
LukasM 02-22-2019 02:54 PM
Nice buy Ryan, it wasn't cheap for a V8 conversion but certainly included a ton of high spec parts and cost much more to build.
The or at least "a" previous owner of your car is on this forum and has been advertising it for several years if I remember correctly, you might get more info from him on the exact spec and technical details.
Ryan_Cunningham 03-15-2019 01:48 AM
Lukas,
Thank you. I got in touch with the original owner who sold the car to the guy I purchased it from and he was able to answer some of my questions. Bottom line, the car is a blast to drive. My wife is a bit skeptical due to the cosmetic condition, but I'm pretty sure the other lady in my wife is convinced it was a great decision!
That being said, I've finished a couple small projects - The weather is still not ideal, but I need assistance with installing the original tachometer which I have in a parts box. I'm not electronically inclined, but have a decent mechanical skill-base. I know there is a tachadapt kit that a user on the site sells for around $70, but anyone have any idea as to how to go about wiring it all up? The car currently has working gauges for water temperature and oil pressure only. I've contacted Renegade Customs as of this morning, but their harness states it only works for 1974 and later cars.
Any help would be greatly appreciated!
http://forums.pelicanparts.com/uploa...1552639612.jpg
http://forums.pelicanparts.com/uploa...1552639636.jpg
http://forums.pelicanparts.com/uploa...1552639659.jpg
Ryan_Cunningham 03-15-2019 01:51 AM
Also, after just viewing the pictures - Any safe way to effectively clean a primer'd surface? The car obviously doesn't have paint yet but I'd like to clean off the oil and grease that got onto the car in the shipping process.
JackDidley 03-18-2019 05:10 PM
Depends on what kind of primer you have but dish soap would be a safe start. Any auto paint store will sell grease remover but it costs a lot more.
lin7310948 03-19-2019 12:57 PM
I have a 71 with a 434 cubic inch sbc roller motor with efi and 930 transaxle. if I can help feel free to message me.http://forums.pelicanparts.com/uploa...1553025389.jpg
Ryan_Cunningham 03-21-2019 12:18 PM
After some thought, I think I'm going to go with aftermarket gauges. Marshall sells some reasonably priced, high-quality gauges and I'm thinking about a fabricating a custom cluster with a large tachometer and speedo, and smaller oil press, water temp, fuel level, and voltage gauges flanking them two on each side. It'll be considerably cheaper than refurbishing the current gauges which look a bit worn.
Comp II LED Performance Gauges and Gauge Sets.
That being said, I've reached out to lin above, but does anyone know there is any reason that the 930 transaxle won't work with the tachometer listed below?
FAQ: What will I need to make the electric speedometer work?
I've done some research and everything I've read indicates that it should provided my sending sensor is working unless I'm missing something.
Also, anyone know what an entire 911 gauge cluster might sell for? And how I might be able to check whether or not they all function appropriately without reinstalling them on the now V8? I know the oil pressure gauge works, but that is the only one currently hooked up.
MrRPJ 04-07-2019 06:13 PM
You really gotta do something with those rear quarters
Ryan_Cunningham 04-19-2019 10:28 AM
It’ll all come in time.
Ryan_Cunningham 08-12-2019 01:49 PM
So I finally got some gauges installed. Looks pretty decent but now I have a bit of a problem. The old Autometer water temperature gauge that the previous owner had installed was reading about 170*. This new Marshall water temperature gauge is reading 210-220*. Nothing else was changed. Can gauges be that far off? I suppose I'm going to go get one of those infrared temperature gauges in order to see how close the new gauge is, but it's pretty disappointing.
jadewombat 08-24-2019 05:18 PM
I wouldn't go by either gauge. Use a voltmeter to check the resistance as the engine warms to verify the sensor is working.
Ryan_Cunningham 08-26-2019 08:46 AM
I measured the resistance and the ohms matched what the Marshall gauge depicted.
Drove the car over the weekend and the temperature stayed about 208* regardless of driving conditions - Idle, street, highway, with an outside temperature of 75*.
When I was seeing hotter temperatures - 215-220* it was 85-90* outside.
gtxracer 01-20-2020 11:39 AM
Any updates to this? Been about 6 months I'd say....
JITARASIA 01-26-2020 12:38 PM
Ryan_Cunningham 01-27-2020 08:28 AM
Not a lot.
When winter rolled around I decided to clean up the interior so I've made some slow progress in there. The PO did a poor job on the interior paint so I stripped everything down to metal and am waiting for a decently warm day to paint the interior. After that I've got some carpet I'm going to throw down so that the wife doesn't feel like she's in a race car, even though she essentially is when we go out on a date night.
I pulled the Sparco race buckets and attempted my hand at learning to sew to reupholster them - Thanks HandBuildByJeff. But after two failed attempts and much time I decided to farm it out to have it professionally done. Looking to do that this week. Depending on the prices I may just go with the Cobra GT3s... They're beautiful but they require $500 to ship from the UK. Not super keen on that.
Also looking at how to deal with the worn dash pad. Its really rough and I'm not interested in pulling the glass right now. I've seen some solid solutions on 911 race cars so I'm looking into that.
Finally, regarding the engine temps. I'm going to modify the DIY ducktail grill I made so the engine can accommodate the original carb spacer that was installed when I received the car. The original gauge showed normal temps when it was installed so I'm thinking that maybe the fuel is just getting too hot? No idea but it's worth a shot.
I'll put up some pictures when I have some worth showing. Just an empty, bare metal interior at the moment.
***EDIT***
Slow progress on account of an upcoming job change and move to San Diego this summer. Along with chasing around a soon-to-be 2 year old. I now know why the projects that move quickly are either done by professionals or older guys without kids.
pvalue 01-27-2020 10:30 AM
I believe that Sube Sports in The US is a dealer for cobra seats and shipping is free.
https://www.subesports.com/cobra/gt3-historic-classic/cob-11117.
Ryan_Cunningham 01-27-2020 01:20 PM
Thanks p, I actually saw them there as well. Interestingly enough, they're actually about $150 cheaper to get shipped from the UK.
I'm going to get an estimate on reupholstering my current seats tomorrow and go from there.
Anyone flying to the East Coast from the UK and care to check a couple Cobra's as their bags for me? They're only $718 for two over there! ;)
Ryan_Cunningham 02-05-2020 09:14 AM
I took two days and cleaned out the interior and sprayed it all with Raptor 2k bedliner. It really looks sharp compared to the condition it was in when I picked it up. I have to still spray the interior doors but I'll post some images once I do.
Also, I was thinking regarding the engine issues I was having regarding a bit of stumbling/hesitation and warmer-than-I'd-prefer running temps. The car when I received it had a cheap Aquus temperature gauge that always read between 175 and 190* regardless of conditions. This was when the car also had no grill on the tail, a carb spacer, and the cheap intake.
Does anyone think it possible that removing the carb spacer has caused vapor lock due to the newer fuels that are more prone to heat problems? I can't really fit a carb spacer under the ducktail grill as it sits even with the low-profile intake. Guess I'll dig into it more once I get the interior pieced back together.
