interesting intake....
as I have been researching LS conversions I see similar things, reverse the intake. is it even possible to not reverse the intake? from pics I can see how a stock deck lid would be in the way. but I have an extended DP deck lid, and suspect it may have room to leave the intake facing the rear.... thoughts? pics? ![]() ![]()
Bob Cox 84 928S, Ruby Red linen/brown interior - preferred DD 87 924S resurrect and gut and another track car... 86 944 turbo my new DE/track car. 78 930 clone project car. |
Very nice car though, I love a slant nose! Last edited by VacantSky; 04-09-2020 at 07:23 AM.. |
That 6.0 you have there is likely an LQ9, it appears to be an iron block. Which will add a little weight to the rear of the car VS the aluminum block LS engines. From what I’ve read the aluminum block LS dressed for the 911 is ~30lbs lighter than the 3.2. And the iron block LS is typically 80lbs heavier than the aluminum block I will be cutting the front of the car, but nothing past an exaggerated RSR oil cooler duct. Hopefully will be making some cuts during some quarantine time next week! Either that or refinishing the Fikse FM10’s I picked up.. |
thanks for the info. I see some people cut a hole in the firewall and extend the air cleaner to the inside of the car. so I wondered is you can do something in the back...
move along ... nothing more to see here ... move along...
Haha! No problem! You definitely don’t have to cut into cabin of the car to make it work at all!
yea there is the RH U and now have seen the cobra neck you found.
but got back to thinking about the intake to the rear of the car...... ![]() realized if I open up the back of the tail, it will be sucking hot exhaust air. so now toying with idea of creating a space on the back of the tail keeping the intake inside... but sometimes the fantasy hits the reality...
914 V8 soon
Vacantsky, I want to thank you and everyone else with the info and photos.
Not much going on recently, but I did get this rennline phone mount in the mail. But instead of using it for a phone I’ll be using it for the Terminator X handheld to monitor the engine on the fly. It’s very sturdy, So I would recommend it for a phone too!
Not much for updates that aren’t LS specific. Just been slowly putting my fuse box in, and really procrastinating on cutting the tub for the radiator.. I need to just get it over with. I can smell the finish line and I’m slowing down for some odd reason.. anyways!
I originally opted to use the renegade throttle cable kit just because I wasn’t too sure how I would connect a cable to the rod or bell crank and I was being a bit lazy.. turns out they out source it to another shop for fabrication and that shop is closed until COVID blows over. I waited for a few weeks and got impatient. I ended up getting a good idea of fixing something to the bell crank while I changed the bushings and decided to take a look at LS throttle cables. I settled on a Lokar 60” cut to fit cable, and a piece of scrap bar stock I had sitting in the garage gave it’s life to become the bracket by the bell crank. If anyone can think for any reason it’s not a good idea have my bracket mounted where it is, please let me know. But I think it should be okay. The nuts are torqued to spec, pics: ![]() ![]() I need to tweak the angle ever so slightly so the crank pulls the cable out straight but it should work perfectly! $80 for a quality cable and a piece of bar stock vs $169 Last edited by VacantSky; 05-24-2020 at 05:59 AM.. |
thanks. I would prefer to use a cable for the throttle rather than drive-by-wire. guess I am just too old school.
dont like the DBY in my F150 or my wifes Audi. when you first dip into the throttle frequently it hesitates just a bit.
Curious if anyone can point me towards a clutch cable? I’m using a 930 trans in what is originally a 915 car, and my 915 clutch cable is too short. Seems there are several different part numbers for cables on the 930’s from my researching. Any help would be appreciated
I have a shortened 930 but haven't gotten to installing it yet and would have thought that the clutch cable was the same. Let me know what you find out.
1989 911 LS1 |
![]() The thread is titled “Frederick the great” I believe Last edited by VacantSky; 11-05-2020 at 06:34 AM.. |
are you using a rengade cradle? from talking to them you need to let them know what gearbox you use as the LS engine and the gearbox bolt to the cradle to get the correct fit.
but I have a LONG way to go....
Here are the torsion tubes of a 930 and a 911. ![]() You can see that the 930 mount points sit a little further forward than the Carrera. Meaning that when you use the 930 carrier on the 930 trans in a Carrera the holes won’t line up. I had to cut and modify my 915 carrier to fit the nose cone of the 930 trans and drill two holes in it so I could hang the engine and transmission seen here: ![]() You can see here how tight the clutch cable is against the throttle bell crank, even with it tight like this it doesn’t reach the clutch arm |
I specifically asked them about this as I have an SC tub and using a short BH 930 gearbox. I have the gearbox support from the 915. will be watching this thread for ideas.
![]() It bolts to the stock LS engine mount holes, and ties to the adaptor plate. My 915 carrier is modified just so I can hang the drivetrain and get the car running but when it’s fab time for the exhaust I’ll have the 930 carrier modified like the picture I borrowed and shared earlier |
Those are some massive spacers
interesting...
I had the impression the RH cradle bolted to the gearbox mounts in the front. so where does it bolt?
Thread Tools | |
Rate This Thread | |
