Go Back   Pelican Parts Forums > Porsche Forums > Porsche Engine Conversion Tech Forum
Originally Posted by DasBoot View Post
Nice work! Where you at in FLA?
Tampa Florida is where the car is. I spend 50% of the year in Asia and now am in Shanghai for the next 2~3 months. I will come home in May for the second phase of my build. I only had 4 weeks home during my last trip and spent 2 weeks getting the engine put together and in the car.
Old 03-07-2009, 08:10 PM
Roc Doc's Avatar
I have the Carerra oil cooler and fan in the Carrera location, and it's just enough cooling in the summer time here. (My car is a 76 with an 85 3.2). If you go that route, then you will still have room up front for a radiator if in fact you are forced that way.
The other thing about a fender mounted oil cooler is that it increases oil capacity, and those LS motors do not like oil starvation at all. There are a lot of trick, baffled, trap-doored oil pans out there for those engines to make sure they always have good oil pressure. An accumulator is also good insurance against oil starvation.
http://store.summitracing.com/egnsearch.asp?N=700+400105+115+4294851301
1976 911S Targa, Carrera bodywork, 3.2l engine.
Old 03-07-2009, 08:20 PM
Embraer's Avatar
I like it!
-mike
Old 03-07-2009, 08:28 PM
Originally Posted by Fizzbiz View Post
Kind of reminds me of the last time I stumbled accross a GREAT porn site, difficult to look away!
Everyone loves porn
Old 03-07-2009, 08:36 PM
Here is a picture if the fuel system. i went with a returnless fuel rail using the stock fuel filter with built in accumulator from a vette. Fuel pressure is maintained at 57psi. I used fuel clamps and slipped the fuel hose over the stock lines with about 5" overlap. Did not see any fuel leaks and will need to monitor. I did see other post of users doing this and would be interested to get feedback if there was ever problems.
Old 03-07-2009, 08:45 PM
I also decided that during my build I was going to remove the stock LS1 PCV system and replace it with an oil catch can and replace the stock valley cover with a newer 2007 version that has the PCV system built in. It cost me less than $100 to do this and I was able to eliminate several hoses and keep it simple.
Old 03-07-2009, 08:53 PM
Had not thought of this, that is the great thing about this forum it is a think tank of information and experience.
Old 03-07-2009, 08:56 PM
Carrerax's Avatar
This is a very cool build!
1997 C4S stock...ish
1970 911T Restored Hot Rod....Sold
http://forums.pelicanparts.com/porsche-911-technical-forum/418411-here-my-new-old-project-lilly.html
Old 03-08-2009, 05:45 AM
I am thrilled to see that another member is attempting this build. Thanks for posting!
I just purchased a '78 turbo bodied roller from another member on here and I spoke to Scott at RH last week. I will be tackling this same project (with a few variations in engine setup) later this year.
Keep up the good work and keep us posted!!!
Old 03-08-2009, 06:07 AM
Here is a shot of the water pump and flexible radiator hose. The flex hose provides just enough movement for the trunk hood to open and close. There is a slight bit of strain on the hose coupling and I am looking for an alternative hose cause I feel over time this may weaken so I am keeping my eye open for a 2" S coupling that is 3~4 ply. The hose coupling I am using now is from an STI radiator hose kit that was sitting around my garage, would probably work but I am not 100% confident.
Old 03-08-2009, 06:19 AM
Almost Banned Once
sc_rufctr's Avatar
I can't get over how the engine "just fits" the 911 engine bay. It's almost like it was made for a V8. (flame suit on) I love my air cooled 911 but this is intriguing for many reasons.
I've hear rumours that the successor to the 997 may have a V8 out the back instead of a flat 8... I'll guess we'll see soon enough but if Porsche goes to a V8 then these conversions will be seen in an entirely new light
Old 03-08-2009, 06:35 AM
mca mca is offline
mca's Avatar
+1
I too am amazed. The engine looks so much taller than the flat six.
Must be hard to put down the project for months at a time. But I guess that affords you more time to draw up your plans.
82 911SC Coupe Chiffon / Chocolate
9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD)
Old 03-08-2009, 07:15 AM
Build looks really sweet..good luck with it..can't wait to see it when its done.
1988 Porsche 911 3.2 (cat delete, K&N drop in filter, chip)
Old 03-08-2009, 08:10 AM
cdrik915's Avatar
Incredible , simply incredible !!!!!
What a job !!!
LIGHTER = FASTER !!!
Old 03-08-2009, 08:56 AM
put me down for a subscription.
Old 03-08-2009, 11:16 AM
Looks good. I am afraid of your radiator hoses though. Those probably cannot withstand being opened and closed much. I don't think they will like being twisted up when hot and could let go and really burn someone. You should think of a safer and better way to do it. Off the top of my head I have a couple ideas but not sure they are any better.
Old 03-08-2009, 12:54 PM
Me likey!!
Old 03-08-2009, 01:11 PM
more PM's than Posts
NY91184's Avatar
Todd, very nice build you have going. When I was looking at your cooling system, an idea popped into my head which I will try to elaborate on. Instead of using the flex pipes to make it possible to open and close the decklid, I think it would be trick to use Hydraulic 90° Swivels mounted below each hinge. These are used with hydraulic machinery and withstand something like 3000psi so that wouldnt be a concern. I'm not sure what size coolant hoses you are using, but they can make the swivels in any size I would guess. I found a few on ebay, the one in the pic below is 1" diameter.
If you attached a 90° elbow to that it would be 180° and would swivel as the decklid was opened or closed. Then throw some nipples on the end to mate up with the coolant lines you already have and it would be a pretty effective solution. The swivels themselves would probably need a small bracket attached to the outboard decklid hinge area to keep them stationary. Heres the link for the auction:
http://cgi.ebay.com/1-HYDRAULIC-HOSE-SWIVEL-90-DEG-ELBOW_W0QQitemZ260342492915QQcmdZViewItemQQptZPneu matic_Hydraulic_Valves_Parts?_trksid=p3286.m20.l11 16
This would probably take some trial and error to perfect but would achieve something great.
Old 03-08-2009, 01:25 PM
Venetian's Avatar
I admire your courage and abilities to take on such a project.
1987 Carrera, Venetian Blue.
Old 03-08-2009, 05:04 PM
After reviewing different intakes and HP gains I went with a typhoon aluminum intake and larger throttle body.
Chevy LS looks great in there. I was told that an LS intake can be reversed and it will still bolt to the motor. Any truth in that statement. Would get the air intake away from the firewall.
Old 03-08-2009, 05:18 PM
