-   Porsche Engine Conversion Tech Forum (http://forums.pelicanparts.com/forumdisplay.php?f=28)
-   -   New Project 76 with 993 GT2 Widebody,LS1,Subaru Box,996 Brakes (http://forums.pelicanparts.com/showthread.php?t=930992)
MrRPJ 02-06-2022 02:37 AM
no cooling issues till the bore split..The radiator i had made had been doing well
Yan2947 02-06-2022 04:38 AM
How high did your coolant temps get?
My temps are always in an area off 180 - 210 unless it is above 85f. Normal driving is never a problem but 3000 rpm’s or higher on a 85 f day and the coolant rises to 220 or. 230 and I don’t let it get higher. I love your coolant lines setup. I still plan a large rear radiator on my 86 but with a smaller radiator up front for those hot days. Are your coolant lines off off the engine block custom or did you order online? Where?
Thx
MrRPJ 02-07-2022 03:33 AM
The coolant headers are from Davies Craig. As for temps. On track I see 100deg c and heavy traffic on hot days about the same. On the highway driving it’s about 90. Don’t forget Ls motors do run on the hot side.
Yan2947 02-07-2022 05:21 PM
Thanks for the info. My build is on hold waiting for the body shop to finish. I will still have a rear radiator but will try to add some smaller ones up front and/or in the rear quarter vents on my slant nose. I have a shortened 930 Tranny for this new project. My 89 has a g50.01 and a LS1 with a very tall 5th gear. Still gets hot but has never overheated and only get hot when it’s 85 f or hotter…
Shuskie15 06-29-2022 02:00 PM
Found your thread after you recommended not using the subaru transmission on my thread. Can you detail the problems you were having with it, and what kind of power you're getting out of your engine?
almostordinary 07-02-2022 10:24 AM
... following. Just missed a great '73 chassis to do this exact project.
MrRPJ 07-24-2022 06:01 PM
First breakage was at 313hp. The output shaft snapped
next was the stub axle.
next was the diff centre
after that 5th gear cracked in half
and that second gear teeth broke.
After that i brought a g96 haha
Shuskie15 07-26-2022 12:07 PM
Did you have the LSD in that subaru unit? What kind of torque numbers? I'm only going to be in the neighborhood of 256hp/247ftlb with the stock subaru 6 cyl.
I'd spoken to you on FB messenger and watched some of your vids, but didn't see any resolution to the adapter and g96 trans. Are you making that commercially available?
MrRPJ 01-10-2023 06:40 PM
Yeah I had a Tomioka lsd, With the old motor I was making about 320hp & 611nm which i thing is about 450ft lb at the wheels. Kennedy will make any any adaptor you want. My adapter is for a ls to gm set up. So im not making any kits. Personally I don't like any engine made by subaru. if you want a flat 6 just buy a 996 carrera engine. then the trans will also bolt up
https://i.imgur.com/7vwAN2q.jpg?2
MrRPJ 04-18-2023 11:21 PM
Had some clutch issues and cable issues which are now sorted. New shifter mount made for cable shift. Routing cables in a torsion tub was the worst thing ever
https://i.imgur.com/fP1xu7q.jpg
https://i.imgur.com/AaGxGSB.jpg
https://i.imgur.com/WTzNuke.jpg
https://i.imgur.com/cJmy5bL.jpg
https://i.imgur.com/mF0bJ0C.jpg
MrRPJ 04-18-2023 11:24 PM
it runs.
Needs a new alpha N tune now for there ITBS. But it sounds cranky with the new engine, Cam is the sloppy stage 2
[IMG]<iframe width="454" height="808" src="https://www.youtube.com/embed/tyhfEZ3R_Lk" title="Built LS1 with ITBS idle in a 911" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" allowfullscreen></iframe>[/IMG]
MrRPJ 04-18-2023 11:46 PM
Finally moving under its own power.
<iframe width="454" height="808" src="https://www.youtube.com/embed/5dYwIRzpxZw" title="Finally moving under its own power again. Built ls1 with Getrag G96 6speed, Next stop tuners" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" allowfullscreen></iframe>
Ryan_Cunningham 04-28-2023 10:52 AM
Badass!
Mr jamo 05-05-2023 07:18 AM
This thread has been very helpful and informative. Thank you for creating it!!
EhisAhiga 07-20-2023 01:26 AM
That's when I lost interest because we're looking at about $6700 + costs for the hydraulic parts which will probably be another grand or so and many hour of research, custom fabrication,
