-   Porsche Marketplace Discussion (http://forums.pelicanparts.com/forumdisplay.php?f=268)
-   -   odometer digits dont line up perfectly (http://forums.pelicanparts.com/showthread.php?t=1024834)
fxdp 03-27-2019 04:44 PM
when someone sells a 911 sometimes they will take a picture of the odometer and post it so that any prospective purchaser can read it for themselves. -0k cool
but what i've noticed is (based on pictures) that at times the individual digits on the odometer don't necessarily line up
not being accusatory but am wondering is that normal for these cars ?
have others noticed this as well ?
porschenut 03-27-2019 05:26 PM
40 year old mechanical odometers using plastic gears. It's a wonder they still work at all.
fxdp 03-27-2019 07:13 PM
ok guess its normal then ty
Rawknees'Turbo 03-27-2019 07:26 PM
I take all odometer claims on these cars as a "maybe".
The speedometer takes just a few minutes to remove (only held in place via friction with the rubber seal that surrounds it), so can be replaced or tampered with with ease.
The odometer drive gear commonly breaks (sheds its teeth when the plastic turns to mush) on these things and who knows how many months or years it takes an owner to have it repaired.
And the electronic versions (all, after some point in the early 70s) can be unplugged in about 30 seconds by removing the cover on the floor between the little jump seats in back and exposing the connecter from the pickup puc mounted on the differential cover.
NYNick 03-28-2019 05:28 AM
My mechanic had to send a speedo out for me a few years ago. He asked me what I wanted it set to. That's what it came back at.
porschenut 03-28-2019 06:42 AM
That's very unsettling.
NYNick 03-28-2019 06:48 AM
Im honest. I had it set the way it went out. No way to tell really.
Sent from my SAMSUNG-SM-G930A using Tapatalk
1979-930 03-28-2019 06:52 AM
The odometer gear set is garbage. The numbers not lining up is normal
Mine broke a couple years ago at 82k ish when I pushed the trip reset. Don't ever push that!
The repair left marks on the back of the trim ring. Any low mileage purchase by me would require a speedo inspection.
The steering wheel and drivers left side bolster are a better mileage gauge.
I love the sub 50k cars where the driver side seat looks like roadkill.
juanbenae 03-28-2019 09:14 AM
the clutch and brake peddle rubber wear can also be a clue. I know those can easily be swapped out, but why would they be on a low mile car even if 40 years old?
porschenut 03-28-2019 10:18 AM
What I meant was that it's unsettling that your mechanic would set the odo to whatever you want, without any concern about how it may be used. That's unscrupulous as well as a federal crime. I know there are plenty of a-hole owners out there who don't care about cheating others, but I expect professionals to hold a higher standard of ethics.
porschenut 03-28-2019 10:25 AM
I pulled the perfectly good pedal covers on my 64k-mile concours car and installed brand new ones, because any wear at all results in a point deduction in competition. I also replaced the plastic escutcheon that surrounds the ignition switch with a brand new one for the same reason. Ditto for the cheap plastic gas pedal. Make all the jokes you want about people who clean their cars with q-tips, but this is a reason why things like that get replaced.
Almost any interior item can be replaced to make an interior match a low-mile odometer. You can also slap a fresh Maaco $1500 paint job on it to make the exterior look the part.
PD41 03-29-2019 09:12 PM
Originally Posted by 1979-930 (Post 10407493)
Mine broke a couple years ago at 82k ish when I pushed the trip reset. Don't ever push that!.
I pushed a trip reset while driving and the odometer broke.
Alway be at a full stop before resetting.
