1970 911S S/R Coupe Rusty Roller
I am looking to to see what others think this rusty roller is worth...
1970 911S sunroof coupe. Originally Bahia Red. At some point in the past someone installed FG rear turbo flares, front FG turbo flared front fenders and apron and painted it white. The car has a rusty front suspension pan, front floor pan, doors, C pillar base, Driver's side inner rocker, area where rear sway mounts on left and right and roof. Rear seat pan and torsion tube are ok. Driver's FG fender was damaged so replaced with a stock steel fender. No motor. What I assume is the original 911/01 and oil cooler are present along with window glasss and frames, gauges and wiring. Car has a title. Now I'll try to load pics.... Thanks in advance... |
Everything is repairable given time and money!
IMHO, the most important structural part on early 911's is the rear torsion tube. Value is highly dependent on that. If it's cracked on that car, given the poor condition and missing engine, I'd sell it for parts. $10K worth of parts? Is the decklid aluminum? It should be. Those used to be $1K, probably 2 or 3 times that now. Ok... after re-reading, the torsion tube is ok. Worth $15K? I wouldn't pay that but someone else might pay more! Transaxle should be type 911, not 901. |
A $150,000 #3 car w/o original motor.......
Motor w/ MFI installed: $35,000 to $40,000 installed https://bringatrailer.com/listing/1973-porsche-911s-4/ https://bringatrailer.com/listing/1973-porsche-2-4l-s-w-mfi/ https://bringatrailer.com/listing/1971-porsche-911s-2-2/ Tires, Brakes and Suspension: $15,000 Interior, wipers & heat: $7,000 to $10,000 Installed Electrical (lights, etc): $5,000 to $10,000 Paint: $15,000 Panels $25,000 Welding $35,000 Based on my very conservative estimate; You would need to get the car for free...... |
roblav..... my error ....the car has a 911/01 tranny not a 901...
What you can see on the outside is 10X worse on the inside; $5-7K (quick sale)…
+1 metal work alone is going to be big $$$
I just sold this one with motor for $12,000 if that gives you an idea of the market for rough longhoods.
Shoot me an email if you need more info adam@unobtanium-inc.com ---Adam http://forums.pelicanparts.com/uploa...1631632616.jpg http://forums.pelicanparts.com/uploa...1631632616.jpg http://forums.pelicanparts.com/uploa...1631632616.jpg http://forums.pelicanparts.com/uploa...1631632616.jpg |
| All times are GMT -8. The time now is 03:21 PM. |
