-   Porsche Marketplace Discussion (http://forums.pelicanparts.com/forumdisplay.php?f=268)
-   -   Value on ‘69 s motor (http://forums.pelicanparts.com/showthread.php?t=1162719)
Ngrich99 06-07-2024 08:47 PM
Hi I’m looking for insight on value on this 1969 s motor. My plan with it is only to use as a practice motor to disassemble and assemble to learn and prepare for the rebuild of my ‘79sc motor when the time comes. There is no known history so assume core motor.
Thankshttp://forums.pelicanparts.com/uploa...1717821864.jpg
Matt Monson 06-08-2024 04:04 AM
Why is the fan shroud the wrong color?
Maybe post the type number and serial number to verify?
Personally, if it’s an S, it is likely worth more as it sits than after you tear it down and put it back together. Anyone shopping for a real S engine for a restoration or hot rod is going to rebuild it again and not trust your work.
nickelplated5s 06-08-2024 05:54 AM
Where's the MFI?
Ngrich99 06-08-2024 06:52 AM
6404214. I have no history so no clue on shroud color or anything else. I would use it to get a feel for taking apart and reassembling but was just curious if any value. Thanks.
Ngrich99 06-08-2024 06:53 AM
Originally Posted by nickelplated5s (Post 12263019)
Where's the MFI?
No history or anyone to ask about that, I’d like to know where the rest of the car is as well…
Matt Monson 06-08-2024 12:17 PM
No such number. It’s probably 610, which would be a 1970 T engine. The shroud is the right color for that. Type number should be 901/03.
$3-4k? Carbs are worth about a grand and the longblock is the balance of the value.
nickelplated5s 06-08-2024 12:57 PM
Matt - 6390793 but 901/10. Was a 2.0 when I got it years ago, correct? Went to a C&C this morning and had 69 parts pointed out. Some I knew, some I didn't.
Matt Monson 06-08-2024 02:25 PM
That’s a 69 S engine.
Ngrich99 06-08-2024 03:10 PM
Thanks Matt appreciate it. Here is a pic of the number as provided to me. http://forums.pelicanparts.com/uploa...1717888151.jpg
nickelplated5s 06-08-2024 05:56 PM
What I was told when I got it and over the years. Just figured you might know. One of those stories when you swap cars for a weekend and I ended up with the pink slip. Back then in CA they were literally pink.
Jim2 06-08-2024 06:37 PM
640xxxx is 914/6
Ngrich99 06-08-2024 08:24 PM
Originally Posted by Jim2 (Post 12263333)
640xxxx is 914/6
Thanks for the info, appreciate it.
mepstein 06-09-2024 03:53 AM
640xxxx is 914/6
Makes sense. It does have a 914-6 oil cooler.
Matt Monson 06-09-2024 04:59 AM
640xxxx is 914/6
Ah-a. I didn’t think of that.
Ngrich99 06-09-2024 08:56 PM
914/6 thanks for the info. If I was able
To mate it with a chassis without a transmission.. what’s it worth now? I really wanted a Porsche motor to practice on but scenario is making this interesting.
1973914 06-10-2024 02:39 AM
More specifically yet this would be from a 1970 914-6 in USA spec and fairly early in the production run. Maybe in the first 300 cars. Even so, as a rebuildable core 4k max.
Matt Monson 06-10-2024 04:40 AM
Yeah, my value doesn’t change with it being a 914/6. It’s basically the same thing as a 69T.
Practice on it without much concern. Once it’s turn down, it’s the case with the serial number that might be of value to some 914/6 owner.
jhynesrockmtn 06-10-2024 05:00 AM
You may want to post the number on 914world.com once you have it. There are guys looking to reunite their factory 6 cars to the original engine.
1973914 06-10-2024 09:20 AM
I went ahead and started a thread on 914world to link it.
rich 06-10-2024 07:03 PM
Still looking for 4371 Not many 914-6 owners really want the 2.0 in the car. More of a shelf critter to say you have it.
