RSR 9x15 Fuchs Valve
While going through a few things, I discovered a couple extra pairs of 9x15 Fuchs
Going to clean them up sometime this week, and a later pair as well
Any idea what the current value these are?
Old 03-02-2025, 09:14 PM
Cobalt's Avatar
I suspect the mag wheel is worth only wall art. Corrosion seems extensive and if acid dipped would most likely show even more loss of material. Probably no longer road worthy.
The 9's are valuable but not crazy money the 11's are the huge money and most aren't true 11's. If you have a pair of 9's condition I would say a grand or so if they are straight and not damaged.
Anthony PCA affiliate '77 member '83 '90 3.8 RS tribute, 91 C4 converted to C2,'93 964 C2, '93 928 GTS M '94 Turbo 3.6, '15 Boxster GTS M,16 GT4,23 Macan GTS,
Gone worth mentioning '71 E '79 SC, '79 built to '74 3.0 RS tribute (2390 # 270 hp), '80 928 euro 5 speed, '74 2.0l 914, '89 944 S2,'04 Cayenne TT '14 boxster, '14 Cayenne GTS 14 Cayman S, 18 Macan GTS many others
Old 03-04-2025, 06:50 AM
