DOT paperwork on eurocars
I am thinking about buying a euro gray market car. The owner does not have the DOT paperwork from several owners ago. If he just has a title from Utah, is that enough to register the car in another state.
Short answer...it depends on the state where you will be registering the car. Some are easy; some are very strict, like CA.
You'll also want to see if the car has the DOT/EPA badge which is usually on the driver's side door jam; this would indicate that the car did go through the proper importation process. If so, you can also call EPA nd DOT (do a search on this forum) and get reissued paperwork.
'71 911E Targa rebuild project, '82 SC, '85 911 M491 cab, '90 C4, '85 911 cab, '77 911 C3 (all sold ![]() |
