How much horsepower.
I found some paper work on my 930. The motor was built by Motor Tech inc. (Anyone ever hear of these guys?). Heres what I found. 1) It has a Kremer 3.4 litre top end including heads and cylinders 8.3 to 1 compression ratio. 2) The cases and heads were machined. 3) Heads were ported. 4) Timing was set to 24 degrees after tdc. 5) Cams were modified to what im not sure. 6) Cam timing was set to 1.9mm at bottom center. 7) Has the ruf intercooler and 4 outlet exhaust. 8) k27 turbo. Thanks in advance for your help.
Old 05-28-2008, 03:06 PM
Somebody has to have an idea.
Old 05-29-2008, 12:30 PM
ttt
Old 05-30-2008, 12:10 PM
racer's Avatar
I'll guess again.. 350-400. best way is to find a local shop with a dyno and get a "real" number, not just guesses. I *think* that to get over 400hp you need to consider twin plug heads and upgraded fuel pressure/pump.
Past:
2000 Boxster 2.7, 1987 944, 1987 924S
1978 911SC, 1976 914 2.0, 1970 914 w/2056
Old 05-30-2008, 02:56 PM
