71 E Targa What's a good Price, Opinions Please
Hi All,
I am looking at a Bahia red 71 E Targa and would like opinions regarding value. Orig. eng. had a rod let go ,it was replaced with a 71 T eng. w/ Zeniths , eng. had top end done 20k ago( owner says it has S pistons and E cams (don't they all)), trans. was rebuilt ,Hydro-pneumatic susp. replaced w/ S struts and calipers, wheels are 15 in. flat sixes (spare still 14x5.5). Body has no rust, v. straight, owner painted car and did a very good job except for two areas that have blistered due to poor prep. (one area is on hood and has no rust on the inside ), interior good but has cracked dash and one cloth covered Recaro and one stock seat, targa top in v.good cond but headliner needs to be glued. Will need carb adjust (rebuild?) ,shifter bushings and could do w/ pedal cluster rebuild. Other than a rough idle, car drives, shifts and stops well. Asking price is $12,000. I have been looking for an early targa and this one would fit the bill, what do you think?
Thanks in advance
Pascal
Old 07-09-2008, 01:00 PM
Carbon Emitter
jkarolyi's Avatar
Looks like a great car for the price! I would take it to a Porsche expert for a rust inspection (lots of hidden underbody areas) and a compression/leakdown test. If it passes, that price is very good. If it had the numbers matching engine it would be worth another $5,000 at least.
Old 07-09-2008, 02:42 PM
Regis turd ab user
Only 935 E Targas were produced in '71.
It should have had the front suspension changed to torsion bars from the hydropneumatic, check to be sure.
It apperars to have 14" wheels which is correct but not too desireable, also has a '74 exterior mirror.
The seats also looked to have been changd out, not always a bad thing.
Check paint code to see if it's original color if that matters to you.
Does it come with the original motor and the MFI?
If it's in solid driver condition, it will be a fun car at very fair price with a future.
Old 07-13-2008, 07:18 PM
andrew15's Avatar
If you buy it - I have a 71E engine case for $250 that you could put on the shelf until the next rebuild.
Regards,
Andrew M
1970 911E - track / weekend car
1970 911S - under restoration
1986 930 Slant Nose - fun car
Current used parts for sale
Old 07-14-2008, 10:24 AM
It sounds like a good deal if the car is in good shape. I replaced the Zeniths on my 911T as they were extremely difficult to get properly adjusted. Budget in another $1500 for a new set of Webers...
1972 911T targa
Old 07-14-2008, 10:47 AM
Thanks all, I did end up buying it, had it checked and it got a good report, will need some work but generally v. good cond. Hope to get it registered tomorrow. Have to run now but will update soon.
Pascal
Old 07-14-2008, 02:23 PM
