Fizzbiz's Avatar
FS: 1980 ROW 911 SC well sorted street/track car
For sale is a very well sorted Euro street legal track car. Hard work is complete. Very agressive suspension package with good compression and leakdown engine numbers.
1980 SC (Euro) VIN: 91A0131234
$19,000.00 OBO
Black Metallic (a solid 10 footer but OK for track car or do re-spary) with black RS interior
172K miles
No A/C or heat but SSI exchangers remain and parts to return heat.
Engine & trans:
Rebuild at 160,00 miles by Air Cooled Classics in Knoxville, TN (as reported by prior owner)
-new head studs
-timing chains
-bearings & rings
-valve job
SSI heat exchangers
B & B exhaust
Compression 120 to 125 all cylinders.
Leakdown less than 5% all cylinders.
SS braided plug wires
WEVO shifter
New clutch and flywheel 7/09
Interior:
Roll bar
Corbeau racing seats
Driver & pass Schroth 6 pt harness new 7/09
RS door panels
RS carpet set (includes spare RS carpet set)
Dino steering wheel
Rennline pedals & dead plate
Reenline floorboards
Rennline Track mats
New sunroof motor
Headlinner needs attention
Small split on dash below passenger defrost vent (very small)
Suspension:
Complete Elephant Racing “Street Track 2 Package” for serious Track and autocross use”
23mm Torsion bar front, plated & plugged hollow
31mm QuickChange Torsion rear
18mm Rear Sway bar bushing, OEM
18mm Front Sway bar bushing, OEM
De-Cambered Ball Joint pair
Ball joint hardware kit
Low-friction control arm mounts
Rack spacing bump steer kit
930 Turbo tie rods
PolyBronze control arm bearing set
PolyBronze spring plate bearings factory plates,
Rear monoball sealed pair
Rear Camber Max adjustment kit with AL trailing arms
QuickChange adjustablespring plate pair!
Tire rub kit
Front strut tower brace
SS brake lines
Lowered corner balanced and aligned (sticks like glue)
Body:
Black metallic (small rust bubbles below rear window gasket)!
GT fiberglass front bumper with splitter
GT fiberglass rear IROC bumper
GT IROC tail
New windshield
Tires and wheels:
1 set Fuch style 8 X 16 and 9 X 18 with BF Goodrich G Force 215 50 ZR16/245 50 ZR 16
1 set Fuch style 8 X 16 and 9 X 16 with Hoosier R6 225 50 ZR16/245 45 ZR16
Extra set tires new and not mounted: Sumitomo 205 55 ZR16/245 45 ZR16
Contact:
lschmidt@kvnet.org
Cell: 270 723 2148
Old 02-26-2009, 01:08 PM
Fizzbiz's Avatar
More photos
Old 02-26-2009, 01:17 PM
Fizzbiz's Avatar
And still more
Old 02-26-2009, 01:28 PM
Fizzbiz's Avatar
Good grief, this was to be posted in the "cars for sale section". Please delete.
Old 02-27-2009, 04:16 AM
