Advanced Porsche 965 Turbo S / 3.8L Twin Turbo : For Sale Private
1989 Porsche 964 Carrera 4 - 3.8L Bi-Turbo : PRIVATE SALE
Engine Specifications - Base Engine, Top End
- All new engine bearings
- New seals & gaskets
- New belts & filters
- Motorsport racing timing chains, new chain guide rails
- Remanufactured Crankshaft - Standard/standard, cross-drilled, balanced
- Remanufactured Connecting Rods -- Converted to SuperCup specs, blueprinted, new bushings, ARP fasteners
- ARP head studs + washers + nuts
- MAHLE Motorsport 3.8L (102mm) Piston & Cylinder Set with 8.0:1 compression
- GT2 EVO Camshafts
- Remanufactured rocker arms + all new rocker shafts with Motorsports seals
- TurboKraft stainless Rocker Locks
- Remanufactured cylinder heads (new guides & Viton seals) + high performance valve springs
- Injectors cleaned & flow-balanced
- All new intake manifold sleeves (rubber connectors)
- Oil tank removed, all 4 oil lines replaced
- Engine has approximately 500 miles on fresh rebuild
Exhaust, Turbo System & Fuel System - Stainless steel headers with heat exchangers, long-tube (big torque) equal length design
- Free-flow stainless muffler with twin 2.5" tips + twin wastegate tips
- Tial Wastegates
- New GARRETT T04/T3 Ball Bearing Turbochargers
- Electric gear-type oil scavenge pump
- Protomotive full-width intercooler -- rear side re-fabricated to delete failure-prone factory rubber boot
- Twin HKS Super Sequential Blow Off Valves
- Bosch GT2 rear fuel pump
Engine Management System - Integrated 3D Boost Mapping
- AEM Engine Management System : Full sequential injection
- Twin ignition
- Twin Lambda sensors : Twin knock sensors
Boost Mapping
Low - 0.6bar (9psi wastegate springs only), 91-octane
- 404.7hp @ 5,914rpm - 9.07psi
- 394.0tq @ 5,028rpm - 8.76psi
- 9.33psi @ 6,474rpm peak
Med - 1.1bar (16.2psi), 91-octane
- 550.7hp @ 5,931rpm - 16.17psi
- 539.5tq @ 4,583rpm - 15.41psi
- 16.14psi @ 4,468rpm (max 16.17psi @ 5,928rpm)
High - 1.35bar (19.8psi), 104-octane
- 657.4hp @ 6,021rpm - 19.74psi
- 650.8tq @ 4,816rpm - 19.74psi
- 19.87psi @ 4,738rpm peak
*All power measurements SAE with DYNAPACK AWD Chassis Dyno
Electric System - New Ignition caps & rotors
- Optima Gel battery
- New starter
- HID (Xenon) headlights
Drivetrain - 993 C4 6-speed AWD transmission + torque tube + front differential
- GT2/GT3 RS Flywheel & Clutch Package: GT3 RS Flywheel -- replaces heavy dual-mass flywheel with 1-piece lightweight steel flywheel
- GT3 RS Flywheel and clutch hardware
- GT3 RS Starter ring gear
- GT3 RS Clutch disc with spring hub, smooth engagement
- GT3 RS SACHS RE Aluminum pressure plate cover
- GT3 RS Release bearing and guide tube
- Porsche updated release fork & updated cross-shaft kit
Suspension – Brakes – Wheels
Sport Suspension System - BILSTEIN PSS-10 Coil-over Suspension System
- MODE Front Upper Monoball Camber Plate Strut Mounts
- MODE Rear Upper Monoball Shock Mounts
- Front strut tower brace
Braking System - 993 Twin Turbo "Big Red" Front Brakes
- Brake system flushed and renewed with ATE "Super Blue" fluid
- Wheels & Tires
- FIKSE FM5 Wheel Set : 18 x 8.5 Front & 18 x 10 Rear
- Bridgestone Potenza S-03 Tire Set : 235/40 Front & 275/30 Rear
- Airbag-delete steering wheel (no airbag on pass side in 1989 chassis)
- Additional boost gauge
Body Exterior & Interior
Exterior - Turbo Wide-body Composite Fiberglass: Flares
- Custom front bumper with fog-light ducts & splitters
- Turbo S rear fender ducts
- Turbo S rear wing
- Genuine Porsche Turbo rear bumper, polyurethane
- Custom heat shields in rear bumper cutouts (prevent tips from damaging bumper)
- New paint
- New front windscreen glass, rubber trim
- New engine compartment sound deadening pad
Interior - New interior carpeting
- Custom door speaker pods
- New radio
- RS style rear seat delete
- Power/manual seats -- manual for/aft and recline
See eBay listing here. Reserve set at 60-70K - Contact us for details!
330383798530
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
12-09-2009, 01:27 PM
