Ice Green '76 911s
I just bought a '76.. I am loosing my mind.. no PPI.. no time cuz I think I got it really cheap.. It blew no smoke and shifted well.. But wondering what its worth... paint is excellent and interior is sorta ratty.. crack on brown dash.. but will clean up really well.. Has aftermarket AC non functioning of course.. (I think its aftermarket.. it seems to fill the smugglers box and says volkswagn on it??) I have no pics yet; in fact I have not closed the deal other than downpayment.. But it looks EXACTLY like this...
http://forums.pelicanparts.com/showthread.php?s=&threadid=229472&highlight=ice+gr een Ice green mettallic in all of its 1970's glory! 180kmiles on the ODO.. the bottom is WONDERFUL.. you could EAT off of it its so clean.. NO RUST cept for a small battery acid leak.. VERY small leak.. All german glass. Brown vinyl interior.. like I said besides the cracks it will will clean up.. original shag carpet.. LOL! Pretty matted but will steam clean I bet.. Manual windows (thank god!). Jack lift points are excellent.. looking inside the tubes you see minor surfce rust and mostly PAINT!! and clearly the inner rockes are ROCK solid. 15" fuchs.. all nice condition.. I did not get paint code but since I saw the same green under the dash its gotta be stock color. Front and rear sway bars.. not sure if they are factory or not.. Whats it worth roughly?? I am sick sick sick!! 2 911's within a month!
JP '76 911s Ice Green Metallic bone stock Last edited by calling911; 12-24-2006 at 12:54 PM.. |
Custom User Title
I think we need a bit more info on the mechanicals, specifically the condition of the engine (still a 2.7?), when it was rebuilt, when the 915 trans was rebuilt, when the clutch was last replaced, condition of the brakes, etc.
With 180,000 on the odometer, the original motor must have been rebuilt at some point in the future. New carpet kits can run $200-300 for low cost carpet to $800 for just German carpet, plus installation costs. If you can not live with the dash crashs, a new dash in black is $1000. If the repaint looks nice, motor is on a relatively fresh rebuilt, trans has been reworked recently and the interior can freshened up easily enough without too much money, this car could be priced anywhere from $7000 to $10,000. Ice Green is a fantastic '70's color! Good Luck! Jay 90 964, 84 3.2 |
Part of the "deal" was not knowing any of the history.. I take it for a test drive in the morning but I just revved it a bit and no smoke.. so I will see.. the deal is hinged on the test drive.. so as long as it goes thru the gears nice and the clutch is there and there is no smoke it will be a deal... I paid WAY less than $7k.. so this is good news if everything else looks good.. I shall report back after the deal is done.. supposed to show up with the rest if the green in the morning.. Oh; and dont know what motor.. how can I tell when I go to look at it in the morning? I'm guessing a 2.7.
JP '76 911s Ice Green Metallic bone stock |
Custom User Title
The definitive answer on the motor will be the engine serial number.
If the car is solid and drives well, you are getting a nice deal if you can pick it up for well under $7000. Best, Jay 90 964, 84 3.2 |
Band.
LOL I called about 20 minutes after you put your money down.
Congratulations. Well, tenatively.
1983 SC Coupe 1963 BMW R60/2 1972 Triumph Tiger 1995 Triumph Daytona SuperIII |
I may sell it in spring.. stay tuned... I'll redo the interior and a few other things... should be really nice when I am done.
It only matters "what's it worth" if you are reselling, imho. If you don't think you paid too much, then you paid just right. Without pics its hard to judge. Since motors cost from $3k-8K, I hope you didn't pay more than about $5k, given its lack of mechanical history.
1970 914-6 Past: 2000 Boxster 2.7, 1987 944, 1987 924S 1978 911SC, 1976 914 2.0, 1970 914 w/2056 |
Here are some pics.. the engine checks out to a '76 california... Anybody know what kind of air conditioning this is (was)?
Custom User Title
What a gem of a 911 in those colors! Nice job.
You know a tranny rebuild is looming in your future. Once you pull that thing, you may as well go through the whole trans instead of just fixing 3rd... Everyone bashes the 2.7 cars, but they have such a great look to them with the mild flares, less 'dish' look to the Fuchs, limited options as compared to the later cars, lighter weight, etc. With a solid motor, these cars are a hoot to drive! Post some more pics of that interior! Good luck with your 'new' 911! Jay 90 964 84 3.2 |
Thanks.. well with 180k on it I am guessing this motor has been fixed.. not an easy verification but I bet it was.. is there a way to check tensioners? Head bolts? Here are some more pics.. the interior is ratty.. needs new carpet and new seats or ulphostery and just plain old hard work.. and the dash is cracked like crazy.. I have not taken off the steering wheel cover yet so I do not know whats under it.. the engine is a california # so I am guessing the steering wheel might be history. The heat blows HOT.. which was nice today in Denver.. I did not know a 911 could make that kind of heat.. I wonder if its worth the effort to remove the A/C from the car.. or would it devalue the car?? And what about California smog stuff.. ?? I wonder if I should remove that? Not sure what "it" is.
JP '76 911s Ice Green Metallic bone stock Last edited by calling911; 12-26-2006 at 04:54 PM.. |
Custom User Title
Good Luck! Jay 90 964 84 3.2 |
Well.. There is an AC compressor, its located on the left side of the engine compartment. But, as mentioned, it does not have the expected under dash AC vents, so I wonder if this was at somepoint a botched "upgrade". Ditch what is sitting in the smugglers box (besides, that is where the lightweight battery can be relocated to
) Looks good in the pics. A few dash cracks but that is not un-expected. Not sure what Co/Denver emmissions are, but your best bet, if it still has its California spec emmissions stuff, is to rip that stuff off, put on some SSI's and a dual outlet muffler (this could net you 10-15hp a "cali" motor was spec'd at only 157hp assuming it is an S.) , then backdate the heat to get rid of those annoying hoses in the engine compartment. Get the wheels refinished. Do a valve adjustment and oil/oil filter change to "baseline" the car and have fun with it. The steering wheel has a funky cover (or the cover is failing) - but that is nothing a nice little Momo wheel can't fix. |
Custom User Title
This car does not have a rear deck lid condenser either, nor does it seem to have the brackets for that deck lid condenser or even the bracket for the A/C compressor. However, from looking at the second last pic posted, there seems to be some sort of vent or opening stuff with maybe a white colored rag... that could be some sort of added ventilation system... Maybe a 2.7 owner could shed some light on that opening and what it may be (or may have been). I do however agree with the use of SSI's and a sport muffler on this motor for a bit more output. Last edited by Jay H; 12-27-2006 at 08:50 PM.. |
Band.
Also; I could see the condensor thru the "firewall" adjacent to the smugglers box.. common area where I've seen it cut out before.. so the condensor is right in the smugglers box.. Here are some more pics.. apparently those are the controls on the floor.. a real mess..
Custom User Title
Calling911, you are right, I have seen A/C condensors hacked into the area below the passenger foot wells and such. This might have been an aftermarket type unit after all. Dealer installed A/C systems on these early cars featured underdash vents and were some of the most effective A/C systems in 911 before the 964 came out. This system seems a bit 'rigged' if I may be so bold... |
Custom User Title
(I'm not flamin' or being difficult, I just want to help if I can!) Last edited by Jay H; 12-27-2006 at 08:51 PM.. |
There is ABSOLUTELY, positively, NO air conditioning compressor on that car, at least not in the pictures you posted.
The rear condensor also is not there. |
I want this car to be all original.. do not plan on messing it up like lots did with the early Porsche's so I am hopefully I can remove this frankenstein.. thanks for correcting me on the oil cooler lines.. I did not know these cars has a front mounted oil cooler.. COOL! I wonder if someone STARTED this job and never finished? HMMMMM.. I wish I had more pics as the car is in storage and I have to make an appt. to go look at it.. but if the car has no compressor then I am hopefull its just gonna be a matter of removing all that gak in the smugglers box.. and then welding in a panel over the square they cut... I found the fan knobs in the "trunk"... I didn't know what they were until I saw the controls laying on the floor as you see in the pic. Also; there are some NEW blower housing laying in the trunk.. again; I bet someone started what they could not finish. Unless maybe someone started removing and got the heavy stuff out and stopped here.. Can't wait to get my '69 restore done so I have room for this baby at home.
