Whats it worth...87 Targa 187 K
I ran across a 87' Targa with 187 K on it its pretty clean...Maint records from last 10 yrs....new clutch in 2010...not sure of the miles at that time, asking 15K in good running order,...but missing all but 1 sticker in the engine bay...??? Thanks FM
could be if its had a top end rebuild, def the type of car you should have a PPI done on before you purchase
____________________ 1985 Carrera: Big Reds = Ass Saver |
Did you get the memo?
With a clean PPI that could be a good deal, G50 cars are the most expensive Carreras, and it's getting hard to find any nice driver for less than $15k. With the miles make sure you pay for a compression or leakdown test.
‘07 Mazda RX8-8 Past: 911T, 911SC, Carrera, 951s, 955, 996s, 987s, 986s, 997s, BMW 5x, C36, C63, XJR, S8, Maserati Coupe, GT500, etc Last edited by onewhippedpuppy; 10-03-2012 at 04:50 AM.. |
Interesting about the missing stickers, may be a clue that it was hit in the back at one time. In my limited experience about removing the stickers, they need to be soaked for weeks in order to remove in one piece with some kind of adhesive remover. I would check the paint in this area for any shenanigans. Then again, someone may have removed them to clean the area up?
Here is a good comparable 89 G50 Targa with higher miles. Beautiful condition and all documents from day one @ $18.9k
:1989 Porsche 911 3.2 G50 Carrera Targa - Rennlist Discussion Forums |
Yes, I intend to PPI if I buy !! Thanks for the Info
