993 purchase
i am looking to buy a 993 coupe...currently i have found two cars both manual...the first is 1995 with 27,000 mi and the other is a 1997 with 38,000miles...and suggestions as to which might be the better direction, assuming the ppi are both positive...tks for all help ..dale c
also need to add that both car are for sale at 40k...
Where do you live? In California, the 95' might be a bit more desirable since it will have the OBD I and you wouldn't have to wrry about the SAI setting off the check engine light.
Otherwise, the '97 would have the Variocam engine, good for a couple more hp's, but the '95 has fewer miles which can be good if its has been taken care of. Absolutely everything is the same otherwise?!?
1992 968 Polar Silver 2010 Toyota Highlander SE 2006 Lexus LS430 ML |
