puddy's Avatar
2.2 motor & 901 trans feeler
My friend has 2.2 motor with webber carbs and 901 trans that he wants to sell soon. It runs & shifts good, i drove the car last night. He'll get compression test numbers soon.
The motor is #6112832, we believe its a 1971 motor.
Any idea on a value for this combo? Are 901's worth anything?
Cheers, Chris
1986 951
SOLD: 1975 Carrera / 965 tribute w/ 1989 3.3 turbo 8.5:1, custom Evergreen K27 7200, 964 cams, euro CIS, TEC1 dual plug, rarlyL8 headers & hooligan pipe.
Old 11-16-2015, 07:11 AM
gearhead
Should be a 71 T engine.
Gearbox should be a 911 gearbox, not a 901. They are not the same thing. One is aluminum and the other is magnesium and the gear ratios are quite different between the two.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 11-16-2015, 07:36 AM
puddy's Avatar
OK, thanks Matt, i'll ask to owner to look for a trans serial number tonight.
Any idea on a value for this combo, is it a $5k combo or closer to $10k assuming everything is in great running condition?
Cheers, Chris
1986 951
Old 11-16-2015, 10:19 AM
gearhead
I'm not 100% up on the engine values, but I would guess $3-5 for the engine. The Webers are worth $1200-1500 by themselves with manifolds and linkages. It would have been Zeniths originally. May be more money in selling the carbs separate.
Now, I am assuming the Webers are not special. If they are IDS carbs from an S or bigger than 40mm that's a different game. You need to look at the stampings on the side of the carbs or pull the air cleaners and look for the extra squirter.
The gearbox, if a 911 box, is worth around $1000.
1974 914 Bumble Bee
2009 Outback XT
Old 11-16-2015, 10:39 AM
jabb's Avatar
sell it while it is still in the car so future buyer can drive and run it assuming you get a local buyer.
If not video prior to pulling
  • Joe A.
  • 84 911 Targa
  • 75 914/6 3.0
Old 11-16-2015, 05:32 PM
puddy's Avatar
Ok the trans has 901/02 stamped on it.
Yes I think he'd want someone to test drive it before buying it. The car is in Oshawa Ontario Canada.
Cheers, Chris
1986 951
Old 11-16-2015, 06:18 PM
Transmission number
Do you have the serial number of the transmission?
Old 11-16-2015, 06:39 PM
Local I would love to test drive!
Old 11-16-2015, 06:46 PM
gearhead
That's a 68S gearbox. Worth $1500-2000.
Definitely check those carbs before you get too far along on any deal.
1974 914 Bumble Bee
2009 Outback XT
Old 11-17-2015, 09:48 AM
blau911's Avatar
Those carbs in the pic's look like Zeniths....
Old 11-17-2015, 09:55 AM
Banned
If someone needs that engine it's worth a lot more than 3-5k. I've seen Ida webers sell for 2500. - 3k alone in the last 3 months.
Old 11-17-2015, 12:19 PM
Yes those look like Zenith carbs
Old 11-17-2015, 02:07 PM
67-68S transmission depending on the serial number
I'd be interested in the transmission alone.
Old 11-19-2015, 08:31 AM
blau911's Avatar
I would be interested in the motor if 914agogo is just looking to buy the tranny.
Old 11-19-2015, 09:45 AM
puddy's Avatar
Thanks for the info guys. The carbs are Zeniths. I had thought the PO said they were webbers, my mistake. The owner has been in touch with a number of people about the engine trans combo but both are still available at this point.
Cheers, Chris
1986 951
Old 11-20-2015, 03:35 AM
