911sc sunroof coupe value
Well I finally might be purchasing my first 911 and found an available SC sunroof coupe that I test drove the other day. The thing I want to ask you guys is your opinion on how much the value will be affected in the long run if the sunroof is taken out and a metal panel is welded in (assuming the mod is perfectly executed). I am just over 6' and wasn't expecting the limited head room. However once I started driving I immediately forgot about that
Taking the sunroof out involves also removing the supporting structure under the roof skin and above the headliner. That's not easily done. Figure repainting the roof, rear quarter panels and cowl. You'll also be pulling out all the glass, installing a new headliner and buying a bunch of new rubber seals for the glass.
To do it right will cost you thousands. Might be better to find a non-sunroof car, even if you have to pay more for it. JR |
I'm 6'5" with a sunroofed 3.2(which I do plan on eventually deleting), what's the issue?
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs 2005 E46 M3- Daily Beater - 3350lbs |
Vintage Owner
It would be cheaper to lower the seat brackets.
I have the same issue with headroom, so I drive either a cabriolet or a Targa.
84 Targa (sold) 70 914-6 (sold) 73 914-6 2.7 conversion (sold) 75 GMC Motorhome (sold) 2016 Cayenne |
I am 6'-2" and no problem with me fitting in current 911 (or any previous).
Perhaps a previous owner was shorter and modified the seats to raise them.
78 911SC sunroof Coupe (SOLD) 97 328i Convertible |
Thanks for the reply JR.
How many thousands are we talking about? I understand that this alteration is quite extensive, but this particular vehicle would eventually need a repaint and the interior redone and figure once I would already be there why not do that also. What do you think of the vehicle's value after such a mod? Will it be severely affected? Martin |
Thanks guys for all of the quick replies!
![]() It was my first 911 experience and this was the obviously the first thing that I noticed when I sat in it. I'm glad to hear that it might be a seat bracket issue and will investigate further ![]() Martin |
Steering wheel spacers go a long a way to helping.
If you do the work when you are repainting the car anyway, then you're probably talking about $3K, because all you'll need at that point is a used roof, some labor and a new headliner. The paint, new rubber and glass R&R will have to be done anyway. If you have a 911 that needs new paint and a new interior, value is not much of a concern. The cars that become really valuable are the original, unmolested ones. If it is tired enough to need new paint and a new interior, it will need a bunch of other stuff, too. That kind of car is more "used car" then "future collectible". An SC is not a rare car.
JR |
I am in the same boat - I am 6'2" and all torso.
Besides making sure the seat is all the way down (if electric) there is a very easy mod you can make to get a tad more room. Pull the seat, flip it over and remove the clips that hold the springs together. They are about an inch long. This will allow the springs to sag a bit and drop you *maybe* 3/4 of an inch. It is a very quick/easy mod - and it allows you to find all sorts of random spare change and old french fries left by the previous owner!
- A pile of British stuff - A growing pile of German stuff ... oh, and two Hondas - complete with car seats and pounds of fish crackers smashed into the carpet (and seats, and door pockets, etc etc etc....) |
Caveman Hammer Mechanic
The real question is, why is there a vase glued to the tree behind the car?
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 |
Blair Witch
Brandolini’s Law: It takes hours more time, research, and writing to debunk misinformation than it takes to spread it. |
Bird Bottle
I am 6'6" and manage to squeeze myself into my '87 Coupe. Admittedly it's pretty tight, and my head is fairly smashed up against the ceiling. However, this is pretty much daily life for me in everything, so I guess I'm used to it. Everything kind of sucks when you're this tall.
At some point I'd like to lower the seat rails. Imagine being able to fit in the car with a helmet on for a DE event. It sure as hell won't happen now. Stig is right, though. Get a smaller diameter wheel than stock (350mm vs. 380mm). Also put a spacer on there, as it really helps with getting your knees in and out. Our host doesn't sell much in the way of spacers, but there are other sites out there that do. PM if you need details. Matt
1987 911 Carrera coupe - Guards Red 2010 997.2 C4S 6-Speed 2005 Mini Cooper Convertible (R52) - Wife's car 1977 VW Bay Window Camper Bus |
