Going Rate for a 3.6?
What should i expect to pay for a 3.6 engine? I see several on eBay for $10-12k but nothing in the forums. Where else should I look?
$8k-$10k, but $12k+ with documented recent rebuild. I've purchased three over the last two years and the only one that did not come as represented, was from this forum. Buyer beware!
The only sources I know of is this form, eBay and LA Dismantlers. |
Lucky to find a nice 3.6 for less than $10k most need rebuilds. Your better off finding a known basket case and rebuilding it. Any documented rebuilt 3.6 will cost you closer to $18k maybe more. Are you including DME harnesses and exhaust in that price?
Be careful with the dismantlers. I tried several times and they all had one issue or another and were well into the $12k range with high mileage and you don't know what your getting until it arrives. |
Somebody needs to start manufacturing these things again, shesh..
You seen what a Polo 4 costs? To manufacture these engine today would be around a $40k engine. Just getting the casting pattern for the case and hitting a minimum production number would be well into 6 figures.
I made far more complicated parts than 964 engine case halves. Mostly defense mil spec parts for Helicopters and it wasn't cheap but no where near 6 figures to start up production. |
]Hi.
3.6 engine case is still in production.. Just order a engine case/block from a G T,3 Cup BR DPHANS |
| All times are GMT -8. The time now is 03:49 PM. |
